check valves for wild vents
Old Nov 1, 2012 | 03:10 PM
  #181
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by muzz3256
is there any way that this could be caused by a blown plenum, as I know that I have a pretty badly blown one...
Yes, it can. Fix the damned thing! Even if you're sporting a gutted cat so it won't lead to cracked cylinder heads, that does nothing to prevent stretched valves which will eventually happen if you don't restore good oil control.
Old Nov 1, 2012 | 03:14 PM
  #182
muzz3256's Avatar
muzz3256
Gotcha. I'm hoping to have the money together in the next month or two to get it fixed, I was quoted $495 labor for the plenum, plugs, wires, cap & rotor, and a new thermostat. I'm buying the parts piece by piece when I have the funds.
Old Nov 1, 2012 | 03:16 PM
  #183
stewie01's Avatar
stewie01
Could always do it yourself and save some $$$
Old Nov 1, 2012 | 03:20 PM
  #184
muzz3256's Avatar
muzz3256
Normally I would, but I've never been that far into an engine, and I have no one to help me this time, so I'd be doing it by my self, which scares me a bit. Sadly this is my only vehicle right now, so if I fubar it, I can't go to work, school, etc, so that's a major concern as well.
Old Nov 1, 2012 | 03:22 PM
  #185
I would do mine myself, I have tihe tools and the garage, etc and probably could, but it just looks like such a pia and I really don't have the time to dedicate to it. I'd gladly pay for someone else to do it, as long as it's not $500. Hell, I'd even help and provide the beer. Anyone interested? Muzz, where you at in central Va?
Old Nov 1, 2012 | 03:55 PM
  #186
muzz3256's Avatar
muzz3256
Charlottesville. I too would be willing to chip in on this lol. I really need to get the plenum done, it'll happen one way or another.
Old Nov 15, 2012 | 10:43 PM
  #187
FirstDodgeTruck's Avatar
FirstDodgeTruck
Default And this is why I work on my own junk...
So I finally got around to looking for these check valves. Lo and behold, the one off the manifold was resting gently on top of the valve cover. Someone has obviously been into this truck...
So my question is this: Would such a vacuum leak (i.e. open port on the manifold) explain erratic shift patterns in any way? It tends to shift 1,2,3,2,3,4,5...
Can't believe I wasn't getting a CEL, at least a lean code or something...
Old Nov 15, 2012 | 10:56 PM
  #188
Ah...a hoo I presume....if I was closer we could tackle this together and get both trucks done.....even though I'm a Hokie...and your a.....whoo?
Old Dec 15, 2012 | 09:19 PM
  #189
woodtrucker's Avatar
woodtrucker
I work at VT and would love to watch this plenum fix! me and a buddy of mine fixed mine almost a year ago! I am now fighting this vacuum problem. Going out in just a minute to find out if I've got two check valves on this 95. It appears that one of my check valves was improperly located. Read through this thread and from what I can tell from a line diagram, is that no check valve should be on the line that comes out of intake on passenger side and goes to (vents,4x4, speed control) correct? The only two cv's I see in the diagram are the ones at the TB and the one near the intake manifold port but they both are looped together. coming out of intake, tee'ing to TB and then to evap canister.
Is my thinking correct on this because that is not where I found one of these cv's. I'm going to see if I can find another right now!
Old Dec 15, 2012 | 09:27 PM
  #190
UnregisteredUser
Incorrect. There should be a check valve there.
