check valves for wild vents
Old Oct 26, 2009 | 10:41 PM
  #61
jjtroutbum's Avatar
jjtroutbum
From looking at my 96' Craig540's plugged hose goes to a line located over the top of the brake cylinder system and runs down towards the evap. canister under the truck on its way to the gas tank. Included a shot of the label under my hood.
Old Oct 27, 2009 | 02:33 PM
  #62
Craig540's Avatar
Craig540
jjtroutbum thanks for the info. I found that line to the evap canaster behing the brake cylinder, i had the brake cylinder replace about 6 years ago so they must have forgot to hook it up. What harm could that hose being disconnected have done.
Old Oct 27, 2009 | 02:58 PM
  #63
Sheriff420's Avatar
Sheriff420
it shouldn't have done any harm. just the risk of having all those gas fumes going around the engine.
Old Oct 27, 2009 | 03:30 PM
  #64
Craig540's Avatar
Craig540
Went to dealer and they charge 30 bucks for the Check Valve and the hose that comes out of the CV connected to the intake manafold, they would not sell me just the CV. The other CV was just 5 bucks, Crazy huh.
Old Oct 27, 2009 | 04:04 PM
  #65
Sheriff420's Avatar
Sheriff420
go to a parts store like advance or oreilleys. they'll have a pcv valve.
you can only get the check valves at the dealer. they were just a few dollars each.
Old Oct 27, 2009 | 04:58 PM
  #66
jjtroutbum's Avatar
jjtroutbum
I went to the junk yard and had several check valves in about 10min. Be sure they only flow in one direction with a quick blow though. Had a couple of duds in my search.
Old Oct 29, 2009 | 06:37 PM
  #67
Craig540's Avatar
Craig540
Unbelievable, I show them the part and they still can't find it. Anyone have a part number for the CV for the intake manafold and the Tee .
Old Oct 30, 2009 | 04:57 PM
  #68
Sheriff420's Avatar
Sheriff420
its PCV and any parts store will have it.
and if you tell the dealer that you need "vacuum line check valves" then they will be able to find them.
Old Oct 30, 2009 | 11:42 PM
  #69
Craig540's Avatar
Craig540
I not only told them but showed him the cv in my truck and he couldn'i find the diagram on his pc.
i will check autozone next.
Old Oct 31, 2009 | 02:06 AM
  #70
Sheriff420's Avatar
Sheriff420
http://shop.advanceautoparts.com/web...S_446747116___
