Lots of oil and smoke comming out of the PCV?!?!?
I have a 360 from 98 with a Kennebell SC.
I had a problem with the plenum and I solved it with the Huges kit.
Right now I have a different problem, there is coming a lot of smoke (and some oil)out of the PCV hose on the driverside of the engine wich goes in to the TB.
Could it be a bad PCV valve or something else?
Whay must I check or rapair?
Thanks and greetings,
Erik.
Erik.
I am living in The Netherlands, Europe There are no dealers or partsstores that sells american parts!
So that is always the problem.
If I buy a $5,- part I must pay 25- for shipping if it costs more the 50,- I must pay 25% importtaxes so that is a problem.
So no ankle to cut off...
For two years ago I bulid myself a World 427 for my Camaro and all the parts where out the US.
Normally I buy parts from Summit ( Summit bills an extra 15 ordercost when you are outside the US)and Rockauto(for the stock stuff) but the don't have that check valve.
So that is the reason I asked.
Erik
Erik
Face it my friend. An American car in Europe is a luxury, so yes you will get ripped off plenty. That just goes with the territory. Foreign cars used to have the same problem here in the states back in the 70's. People were crazy to buy foreign cars because parts could take months to get here. Now it has all changed. At least you have the internet to help you. Google will become your best friend. Good luck.
Trending Topics
A compression test won't tell you where the problem is, in other words, whether it is valves, rings or valve seals that are leaking. Generally, a pressurized crankcase only happens with worn rings. A leakdown test can pinpoint this and indicate the rate of loss. Since you have a supercharger I would guess your rings are shot and the SC is just forcing air past them and into the crankcase, which then forces much of the oil mist to find the path of least resistance. That would be any hoses like the PCV or vents.
