stuck rear door on 1998 ext. cab
It could be a problem with the 98's or it could be something about careless owners. That problem may have to do with either snow and road salt getting in there in snow areas, and in non snow areas people not opening the doors often enough and cleaning them. I'll bet a lot of people don't even bother to open doors and dry their door frames when they wash their trucks. I do, and that's how you keep your door frame paint in perfect condition, your moldings from getting eaten up, and how you keep doors from rusting shut.
i know on my truck i had the same problem but it was an 02 ext and the passenger back door was not going to open even when i used the latch , and so i took off the outer door handle it had i think 2 screws and pulled the latch inside and it opened right up so its that simple make sure u pull on both latches in side the top one went down and the bottom one went up their u go
Most 98s dont have the mpg option on the overhead computer that is the year they switched the interior from the old boxy one to the rounded on you see on the 2000 and above rams. I have a 98, my dad has an 01 and my buddy has another 98. My buddys truck has the boxy interior which is weird because its the same as mine. my dad has the round interior and my truck seems to have a mix of both. It looks like the 01 but a few things like the passenger airbag switch and the power outlet and overhead console are all different and in different locations.
Not sure if you can just pull the handle, and get at the rods that way.... My truck doesn't have the rear doors, so, mine are permanently stuck closed.
