Procharger 408 ready to install, whaddyathink?
#61
worked on the blackbird right.... but then again, well hell maybe that truck can fly...
indy, one word. omfgwththatiseffingamazinggolfclappleasesiridlikes omemore. well... you get the point.
so far imho on a 1-10 scale id have to say this hits about a 12.3-12.75 easy.
removing the weld splatters.... tip of the hat.
def makes me wanna start on my 78 lil red express asap.
#63
#64
#67
Just checked Summit, they have a shipped date on the control arm bushings that keeps extending every time I check. Currently at Aug29th. No word from buddy on his set yet. Stuck in limbo a bit here, cant really drop the motor in till I can get wheels under it. Think Ill call Energy Susp tomorrow.
Still making brackets up slowly but surely. Fuel rail brackets a bit of o biatch. Need to find a better way of bending the alum so the bends are tighter. That or I have to pull the 2bbl adapter and take it down on the side a bit(where I cut off the horns) to allow more room.
Debating on going with 2 different exhaust setups, one using a pair of 3" Magnaflows.
One just a pair of 3" straight pipes that will exit at the back of the doors on both sides. For street will be getting an H pipe made up and running the twin Magnaflows exiting both sides at the front of the bed.
