gears
Old 08-07-2009, 04:42 PM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
Default gears
I have posted a couple questions about gears before but i was wondering if i run 36" tires and have 4.88 gears will i be able to haul a 20' ski boat. My fiance has decided my next purchase is a boat lol.
Old 08-07-2009, 04:48 PM
95MaroonMonster's Avatar
95MaroonMonster
95MaroonMonster is offline
should be able to, how much does the boat weigh and what is your truck
Old 08-07-2009, 05:09 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Dodge Forum Moderator
Can't tell you without knowing at least the estimated weight of boat and trailer, and a little info about your truck. Model year, 1500/2500/3500, engine, etc.
Old 08-07-2009, 05:11 PM
SpcD1500's Avatar
SpcD1500
SpcD1500 is offline
and this is why i am getting all my toys paid off before i even think about looking for a serious girlfriend. hahahha
Old 08-10-2009, 11:59 PM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
It's a 97 1500 5.9 4x4 and I don't know an exact weight on the boat but I don't imagine too much it's only a single axle trailer.
Old 08-11-2009, 12:36 AM
95MaroonMonster
hell single axle trailer, you'll be just fine, just lock out OD, and keep an eye on engine temp, and trans temp if you have a gauge
Old 08-11-2009, 02:06 AM
Miami_Son's Avatar
Miami_Son
Miami_Son is offline
Did you already put the gears in? Probably won't be able to get 4.88s in those wimpy axles. Might not even get 4.56s in them, but I think that's the biggest you can go on the 60. Better consult a good gear shop.
Old 08-11-2009, 02:10 AM
mikey0469's Avatar
mikey0469
mikey0469 is offline
easily!!! i pulled a 24" dual tandom axle car trailer 1600 miles loaded with about 2000 pounds loaded onto it. im runnin 35s with 4.56s. i do NOT see a problem.
Old 08-11-2009, 07:49 AM
olyelr's Avatar
olyelr
olyelr is offline
4.88's can be purchased for the half ton axles, but that is the lowest (due to the 9.25" rear). As far as the dana 60 goes (which he dosnt even have), I believe you can purchase up to 7.17's (just in case you wanna run 54's )
I think 4.88's and 36's is a great tire/gear combo that should serve you just fine. But dont go thinking you can tow the world just cause you have gears (although a single axle trailer/boat will be just fine).
Old 08-11-2009, 11:09 AM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
I was told to go 4.88's with 36's. Do aal's really help the back end not sag as much I've got the skyjacker heavyduty 4" aal's.
Quick Reply: gears
