Need this truck running tonight ASD?
Old Sep 24, 2009 | 06:40 PM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
I know this will be a bit of a stretch, but was the key in and the ignition switch in the on position when you connected the battery charger? Just trying to help.
Old Sep 24, 2009 | 06:47 PM
  #22
wayfast1500's Avatar
wayfast1500
Honestly I dont remember, I can tell you the 140 amp alt. fuse fried though.
Old Sep 24, 2009 | 07:17 PM
  #23
zman17's Avatar
zman17
Ouch!
Old Sep 24, 2009 | 09:17 PM
  #24
wayfast1500
assuming by your responce its most likely the computer?
Old Sep 25, 2009 | 06:41 AM
  #25
zman17's Avatar
zman17
No, but in the millisecond it takes for a fuse to blow, anything can happen.
Old Sep 25, 2009 | 12:14 PM
  #26
wayfast1500
Is there anything else in the system that can cut the power to everything? There are no fuses blown in either the pdc or the fuse panel inside the cab, and all my lights/guages/starter works.
Old Sep 26, 2009 | 07:06 AM
  #27
zman17's Avatar
zman17
I guess I would try a new ignition switch, then move on to the PCM. Maybe you can get one cheap at a junk yard to try.
Old Sep 26, 2009 | 07:50 AM
  #28
jradams350's Avatar
jradams350
Does it have an Cam Position Sensor. I am not fimilar with the newer Dodge trucks, but if it does have one, check it as well since it will trip the ASD Relay and cause all sorts of issues.
Another thing to think about since nobody has mentioned it yet, have you tried pulling the codes? If it can pull the codes and show some P codes, then the PCM May of survived since it is protected by a fuse or 2.
Old Sep 26, 2009 | 08:31 AM
  #29
wayfast1500
Yes it has a cam sensor, I just replaced it, also the coil was tested along with the alt after the battery charger was hooked up backwards. It has new plugs, dist. Cap, plug wires, rotor.
Old Sep 26, 2009 | 08:32 AM
  #30
wayfast1500
Also I plugged a code reader in, it hasn't thrown any cel's and there was no codes in the computer.
