Old Aug 4, 2015, 07:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
I.O.D. (Ignition Off Drain) Fuse
Old Jun 28, 2016 | 02:25 PM
  #21
not2techie's Avatar
not2techie
Spent quite a significant amount of time looking thru my Haynes and owners manual to try and find out what IOD was. Should've known to just come here first! lol
I am having a similar problem as brents1986 had. Although, last fall when I could not locate any options (switches nor fuses) to turn off interior dome lights, I just pulled all of the bulbs out.
I hope I am posting this in the correct location (I have a very difficult time navigating on a phone) and the thread is not too old to get some replies.
Last week, I discovered that the exterior back up light, on top of the cab was on, many hours after I had parked the truck.
Was able to turn it off by pulling the IOD fuse out. And figured my immediate issue of battery drain was solved.
Found out today, I was wrong. Truck is deader than dead. Going to start diagnostics with a spare battery....but, of all things to go wrong, electrical is the worst for me. It is in fact what inspired my purchase of this Dodge last year...can't figure out why I have no tail lights in the old truck! (Yes, the wires, but where)
Anyway...any ideas what I should look for ?
in the 2001, Dodge 2500 5.9
TIA!
Old Jun 28, 2016 | 03:05 PM
  #22
The lights on the back of the cab aren't reverse lights, those are cargo lights. Usually turned on by the headlight switch.
If you don't have one yet, get the factory service manual for your truck from here. Wiring diagrams are in section 8W.
Check the underhood light, and the glovebox light, see if those are staying on. If your domes are on all the time, check the door jam switches, also, make sure they are turned off at the headlight switch...
Old Jun 28, 2016 | 04:37 PM
  #23
not2techie's Avatar
not2techie
This might get off track, idk, not sure if I should start a thread?
I will check for those lights when I get a battery in. I have the cable ends cleaned up now, and found this cut wire while doing that
Yellow jacket wire cut
Looks like it was cut long ago from a PO. Do we think it is relevant?
Old Jun 28, 2016 | 04:41 PM
  #24
Probably not. More'n likely it was something that was removed when one of the previous owners sold the truck. Of course, that could possibly imply that there is other wire-butchery going on elsewhere.......
Old Jun 28, 2016 | 05:38 PM
  #25
not2techie's Avatar
not2techie
Okay, yes I'm sure there is. Here is what I know right now...
There is a significant draw on the battery, with and with out the IOD fuse plugged in. (Keys in off position, lights switches all off)
In addition, the cargo light stays on with the IOD fuse plugged in. I have dome bulbs all pulled out, because I frequently leave doors open for extended hours.
The under hood light does not turn on that I can see. Nor glove box.
Can I drive the truck safely with the IOD fuse pulled?
I have some wiring diagrams in my Haynes, but need to visit the library to download the manual from here. And, at this point, clearly I have something more problematic than just the IOD, so will start a new thread after I research more, and am still stumped.
Old Jun 28, 2016 | 09:17 PM
  #26
Listen carefully to your truck, with everything turned of. See if anything is still running.
Monitor the draw, and start pulling relays. Stuck relay on say, the a/c, would be a pretty significant draw.
If none of that turns up anything, start pulling fuses one at a time, until the draw goes away. That will at least clue you in to which circuit it is.
Might wanna pull the headlight switch, and check the wiring at the back. They are famous for melting, and causing some interesting problems. (including fires.)
Old Jun 28, 2016 | 10:08 PM
  #27
not2techie's Avatar
not2techie
Oh Wonderful! No fires yet. lol
For tonight, I have the negative cable pulled off the battery. Will be back at it tomorrow.
I'm not absolutely positive, but it sounded like this might be making noise. No clue what it is?
Under dash, near floor, heat vent in background.
Just a little to right side of gas peddle, up by firewall.
Last edited by not2techie; Jun 28, 2016 at 10:12 PM. Reason: forgot to include my amused reaction.
Old Jun 28, 2016 | 10:33 PM
  #28
Vacuum Actuator. There are a couple scattered around under the dash. All your vents are vacuum controlled. No electric involved.
Old Jul 3, 2016 | 04:51 AM
  #29
Friar Tuck's Avatar
Friar Tuck
Talking I.O.D. Fuse
There are a few things that are connected to the I.O.D. fuse:
Left Visor/Vanity Lamp
Right Visor/Vanity Lamp
Underhood Lamp
Radio
Glove Box Lamp
Power Mirror
Dome Lamp
Cargo Lamp #1
Cargo Lamp #2
DLC Connector (need this to retrieve codes)
Map lights
Your Cigar Lighter still works, tho!
Old Dec 2, 2016 | 04:04 PM
  #30
Hillbilly Emes's Avatar
Hillbilly Emes
Default iod/abs
was woundering if the i.o.d. or abs/RWAL fuse could case the speedo to quit working
