Another "hard to shift out of 4L" Thread...
Hi Guys.......
Recently I took my 1997 Dodge Ram (5.9 L, Auto Transmission) out on a few relatively easy jeep roads. I easily shifted from 2H to 4H and back numerous times on the fly with no problems whatsoever.
One part of the jeep road required 4L. I know I’m supposed to be able to shift the transfer case while moving at a low speed (2-3 mph) but I’ve never done this. I always stop my truck, put the automatic transmission in neutral then move the transfer lever down to 4L.
Moving the lever took a very hard pull, but it worked just fine and I did some minor rock crawling in 4L.
Once I cleared the tough spot in the road I tried to put the truck back into 4H. I stopped, put the transmission in neutral, but the transfer lever wouldn’t budge. I tried several times and finally using much more force than I wanted to use got the level back to 4H.
So I’m wondering just how the rest of you (who drive off-road) deal with this situation? I've heard of some people who experience this actually turning the engine off, shift the transfer lever, then restart the truck. (I've never tried this) Any tips would be appreciated……
Thanks
Jason
Thanks
Jason
mine requires a pretty hard throw to shift in/out of 4L. I always come to either a full stop or a 1mph roll, always shift transmission to Neutral, and then yank the hell out of it. Usually it will shift all the way through t-case neutral to wherever i'm headed. occasionally mine will get hung in t-case neutral. if it does, then its going to grind if i push on it anymore. so i turn the engine off, and it generally makes the rest of the shift easily.
i read somewhere that the 4L shift is difficult due to no synchronizers.
Anyway, I've got to try shutting the engine down, just to see how it works for me......
My Dodge Ram is the only pickup I've every owned...... and I love it... except of the 4L situation we are discussing..... Do other pickup trucks (Chevy, Fords, etc) had the same problems with 4L as the Rams?
Trending Topics
with the engine off, the throw is very easy. it probably depends on whether there is any tension on the drive line.
