EGR Code 32
Old Feb 21, 2010 | 09:14 PM
mjackson92rs's Avatar
mjackson92rs
Default EGR Code 32
My truck has been throwing Code 32 which relates to the EGR and EGR Circuit. Anybody have any experience with this code and if so, what was the cure?
95 2500 4x4 5.9L 360 V8
Old Feb 21, 2010 | 09:18 PM
Gerehead8's Avatar
Gerehead8
Do you have to pass inspection?
Old Feb 21, 2010 | 09:31 PM
mjackson92rs
Yes it must pass pennsylvania emmisions so the EGR must stay on.
Old Feb 21, 2010 | 10:42 PM
master tech's Avatar
master tech
Site Moderator & Tech
Ck the EGR valve, sometimes the harness or the valve melts because of heat.
Old Feb 21, 2010 | 10:43 PM
halfamil's Avatar
halfamil
I put a new EGR valve on mine and it cured it.I've heard you take it off and clean the valve and tube to fix it for a while.Does the CEL stay on all the time.Mine started out from, just every now and then, to, quite often, to on right after start up.You may be able to disconnect the neg. cable for a few minutes, and get it inspected.
Old Feb 21, 2010 | 10:51 PM
mjackson92rs
Right now I'm at the "every now and then" point. I'm doing the plenum next week so I will clean the valve then to see if it helps. Now the question is, how do I go about cleaning out the EGR?
Old Feb 21, 2010 | 11:09 PM
halfamil's Avatar
halfamil
It's just a small valve and tube. If your taking the intake off, you'll see how to clean it up.Good luck Man.
Old May 25, 2010 | 03:47 PM
mjackson92rs
back from the dead. Truck began to start throwing this code again today. Can an EGR malfunction lead to a crappy MPG? Truck hasn't been doing good on gas at all lately and am hoping this is somehow related to that.
Old May 25, 2010 | 04:01 PM
Yep, if egr is malfunctioning, the computer will pull timing to compensate.
Old May 25, 2010 | 06:19 PM
95RAM360's Avatar
95RAM360
i have the same code, but its not my egr valve, but actually the EGR pipe (cut it out)
when you did the plenum you have to of taken that pipe off...maybe its not tight enough back to the manifold...
and i get 14 mpgs city without the EGR pipe, so i doubt thats the cause of poor mpgs...it will contribute, but wont be the leading cause
