Seized axle nut
Old Aug 6, 2010 | 06:23 PM
  #31
Sheriff420's Avatar
Sheriff420
Glad to hear it. Now don't forget the anti-seize when you put it back together.
Old Aug 19, 2010 | 09:33 PM
  #32
Agostage's Avatar
Agostage
Next question - I'm confused on what to pry against to get the carrier out - mine doesn't seem to want to budge - anybody have pics of what they did?
FYI sheriff - I've covered everything in anti-seize so far
Old Aug 19, 2010 | 09:39 PM
  #33
Turn the carrier so that the solid part the pin passes thru is facing out toward you. Stick your prybar under that, and stick a block of wood, or somesuch, on the face of the housing that the cover bolts to. Pry gently. Having a friend to help comes in real handy, as the carrier is not exactly light.
Old Aug 19, 2010 | 10:18 PM
  #34
CBR900RR19's Avatar
CBR900RR19
I know you guys finally got the nut loose but as far as I'm concerned this stuff is the sheeeeeeeet!! LOL AeroKroil has never failed me!!!
http://www.kanolabs.com/
Old Aug 19, 2010 | 10:39 PM
  #35
dhvaughan's Avatar
dhvaughan
i used sheriff's trick and wrapped a strap around the carrier and hooked it to the come-along and the come-along to the tow hook. it worked good.
Old Aug 19, 2010 | 10:53 PM
  #36
calgaryman's Avatar
calgaryman
+2 on the come-along... popped mine out with no trouble
Old Aug 19, 2010 | 11:39 PM
  #37
northernRAM's Avatar
northernRAM
big breaker bar!!!!!!
Old Aug 20, 2010 | 08:57 AM
  #38
Agostage's Avatar
Agostage
Lots of great input - thx - I don't have a com-along, I'll just try to rig up something with a large bar
Old Aug 20, 2010 | 09:01 AM
  #39
Sheriff420's Avatar
Sheriff420
The come along deal works pretty good. I actually hooked one end to the hitch on my dads truck and had him cranking on it while I was under there with an old pair of jeans on the carrier to catch it without getting cut up by the ring gear.
Old Aug 20, 2010 | 09:17 AM
  #40
Gary-L's Avatar
Gary-L
Veteran: Navy
I've heard from others about the wonders of Kroil. IMHO, WD-40 is for amateurs who wish they could wear big boy panties.
