MonteC's Transmission Corner (For Info Only)
Old Apr 30, 2010 | 08:17 PM
  #201
95RAM360's Avatar
95RAM360
so thats not needed? its fine without?
could other little pieces be in there, and could they clog one of my lines?
Old Apr 30, 2010 | 08:19 PM
  #202
MonteC's Avatar
MonteC
Nothing to worry about, if any more of those zip ties come loose they will just fall into the pan. They cannot pass through the filter.
Old Apr 30, 2010 | 10:09 PM
  #203
corbin5754's Avatar
corbin5754
Default tranny swap 360 out of 318
Quick question I have a 95 dodge ram 4x4 5.9 AT im getting a used tranny from salvage yard but its coming out of a 94 dodge ram 4x4 318 AT is it a even swap no changing anything
Old Apr 30, 2010 | 11:14 PM
  #204
MonteC's Avatar
MonteC
The units are the same but i dont know for sure if the converters are, I would do a physical check of the converters, worst case the stall speeds are different, which wont be a huge deal. Make sure you keep your original unit until you have the used unit in and working. I cant count how many times people have given up their original units and then only to have problems with the used unit and cant get their original back.
Old May 1, 2010 | 07:12 AM
  #205
95RAM360's Avatar
95RAM360
thank you MonteC, appriciate the info...made me feel MUCH better
Old May 1, 2010 | 06:21 PM
  #206
secrt007agt's Avatar
secrt007agt
Default 4 Speed Auto Trans 47RE Shifting Problem
I have just bought a 2001 Dodge Ram 2500 Diesel w/Auto Trans.
I have noticed that sometimes (with OD on or off) that it shifts quickly between 3rd & 4th back & forth until the speed gets fast enough to stay in 4th. At first I thought is was an OD problem, but it will happen even with OD in the off position.
I don't have a history on the trans, so I need some ideas????
Thanks in advance.
Old May 1, 2010 | 06:36 PM
  #207
BlueBeast2's Avatar
BlueBeast2
sounds like tc lock up to me. If it is I believe that's normal. Very annoying
Old May 1, 2010 | 08:26 PM
  #208
corbin5754's Avatar
corbin5754
what about putting my original converter in this tranny im getting what make a converter bad....thanks for your help again
Old May 1, 2010 | 09:08 PM
  #209
MonteC's Avatar
MonteC
Thats what i think it is.
Old May 1, 2010 | 09:10 PM
  #210
MonteC's Avatar
MonteC
Since its a used unit i wouldnt worry about putting your old converter in the other trans. If it was a rebuilt trans i would NEVER put a USED converter in it. If the old trans would not move forward or backwards dont use the old converter.
