MonteC's Transmission Corner (For Info Only)
Old May 1, 2010 | 09:10 PM
  #211
yakkier's Avatar
yakkier
Hey monte im back again, this time my truck.
My 94 has been shifting later from 3rd to 4th, it wont shift into 4th untill it hits around 3400. It shifts smooth so im not too too worried about it but i still dont like it getting that high before it does shift, my fluid is fine and it's got a newish filter. It only does it in 3rd every other gear shifts as it always has around 2k, any ideas man ?
Old May 1, 2010 | 10:51 PM
  #212
MonteC's Avatar
MonteC
The 3-4 shift is electronically controlled. You may have a bad ground, lazy solenoid or lazy computer.
Old May 1, 2010 | 10:54 PM
  #213
yakkier's Avatar
yakkier
i'll double check the wiring, wouldnt surprise me if it was an electrical issue.
Thanks as always monte
Old May 2, 2010 | 07:02 PM
  #214
corbin5754's Avatar
corbin5754
reverse works fine, and it wont kick into 2nd gear at all anymore
Old May 2, 2010 | 08:58 PM
  #215
95RAM360's Avatar
95RAM360
dumb question, and thought id post it here because im not in a rush for answer....
what size wrench would i need for the transfer case fill hole? my biggest wrench is a 1 1/8th and thats to small.
thanks
Old May 2, 2010 | 09:53 PM
  #216
J415's Avatar
J415
thanks
Check it with a dial caliper.
Old May 2, 2010 | 10:36 PM
  #217
MonteC's Avatar
MonteC
Maybe a fallen 2nd gear band strut. Not much info to go off of.
Old May 2, 2010 | 10:39 PM
  #218
MonteC's Avatar
MonteC
thanks
Off the top of my head, not a clue. 1 1/4 maybe. Havent done many t cases. My r&r guys do the services.
Old May 3, 2010 | 10:06 AM
  #219
tango-52's Avatar
tango-52
Originally Posted by mtndawg
Quote:
Thanks for the responses. Luckily, I don't have to fix mine immediately. I'm working on my Porsche 914 currently. I hope to have that on the road in the next week, then move on to the truck. I don't have any experience with an auto transmission, but I know my way around the toolbox and shop manual pretty well to figure things out! tango-52 let me know how you're work goes. I really don't know what level of transmission knowlege is required to work on a band strut or reverse servo, or even troubleshoot.
I dropped the pan. There were a lot of fine shavings on the pan magnet and a piece of a snap ring. I tried adjusting the rear band, but didn't have the right socket. An 11/32" 12-point almost worked, but would slip before my torque qrench clicked at 72 in-lb. I backed it off two turns and tightened the lock nut up. I also changed the OD solenoid assembly, then put on the new deeper pan and added ten quarts. Still no reverse. Next I will get the right socket and try again. Otherwise, it's $2k for a new transmission. I only paid $2500 for the whole truck! And I feel your pain on the 914. I have three. Two run and one is for parts.
Old May 3, 2010 | 10:17 AM
  #220
BlueBeast2's Avatar
BlueBeast2
If your finding pieces in there why even bother? I have a feeling you're gonna be buying another one
