MonteC's Transmission Corner (For Info Only)
Old Aug 12, 2010 | 08:48 PM
  #651
MonteC's Avatar
MonteC
Originally Posted by Joshfinn
The dreaded tranns code... I have a 2000 dodge ram 1500, 5.9 gas, 46re. The problem im having is a recurring tranns code p1740. I bought the truck will 100k mi on it not sure if the transmission valve body pressure boost valve cover plate has been replaced (i read in a tsb something about some orifice not being large enough on the plate) 1 month after buying the truck the code popped up, luckily at the time i had a 1k mi warranty. I would have to let off the pedal and wait a second or to for it to shift. Took it to the dealer, they swapped out the 2 solenoids/filter/fluid.... Code = gone/no more symptoms.... 1 month later the code came back. The truck shifts fine, and has no symptoms at all. I've cleared to code multiple times, and the code come back with a vengeance after 30 miles..
Any ideas what could be causing this problem?
-Josh-
I need to know exactly what code.
Old Aug 12, 2010 | 08:51 PM
  #652
MonteC's Avatar
MonteC
Originally Posted by isenegger
no i mean when im doing 60 or 70 down the highway and i floor it to pass it DOWNSHIFTS a gear or two and while its in that gear as soon as the rpms reach about 4000 or so its like it goes to neutral or something. so i always just let off and it goes back into gear. anyone else had theirs do that?
Sounds like the third gear clutches are letting loose under heavy acceleration. How many miles are on the trans?
Old Aug 12, 2010 | 08:52 PM
  #653
MonteC's Avatar
MonteC
Vacation from August 14th through August 28th. Cross country road trip. Thanks.
Old Aug 13, 2010 | 02:08 AM
  #654
J415's Avatar
J415
Have Fun boss. I'm sure your looking forward to it.
Old Aug 13, 2010 | 11:30 PM
  #655
redneck_ram's Avatar
redneck_ram
ive got a 2001 dodge ram 4x4 5.2. the transmission just went and i have the opportunity to get a rebuilt one from a 97 ram 4x4 5.2 with 25k on it for 400 bucks. will a 97 transmission fit into my 2001 without having wiring issues or anything like that? any help is greatly appreciated. thanks.
Old Aug 14, 2010 | 10:35 PM
  #656
m2hbvic's Avatar
m2hbvic
Thumbs up
Hey Rob, have a great trip! Lord knows you deserve it after all of the help that you've given to all of us with our transmission problems/questions!!!
Hope you don't have any transmission troubles on your trip across country. Just kidding!
THANK YOU for all your help, advice, and recommendations.
Old Aug 16, 2010 | 01:21 PM
  #657
WillyB4x4's Avatar
WillyB4x4
Default sluggish downshift when stopping
hoping you can help....my 01 1500 is sluggish to return to 1st if I do a rolling stop or do not completely stop. Gov Pres pak replaced, new vehicle speed sensor and tps all done. No trouble codes. drives great otherwise. wondering if this could be an adjustment or valve body issue?
Old Aug 16, 2010 | 10:19 PM
  #658
isenegger's Avatar
isenegger
less thank 40k on the rebuild. will it hurt it to drive in normal and dont dog it? it seems to do ok
Old Aug 19, 2010 | 02:55 AM
  #659
jasonw's Avatar
jasonw
Site Moderator
Locking the thread for Monte's vacation. Will reopen it when he gets back.
Old Aug 31, 2010 | 04:44 PM
  #660
jasonw's Avatar
jasonw
Site Moderator
Reopening the thread, as Monte is back.
Welcome back!
