MonteC's Transmission Corner (For Info Only)
Old Sep 16, 2010 | 09:51 AM
  #721
DodgeMagnum318's Avatar
DodgeMagnum318
Default 46re problems
i recently found pieces of aproxx. half my OD snap ring (thanks 95ram360 for the info) in my trans. pan while doing an fluid flush. i had it looked at about a month ago for a serious whining sound that is occuring and was told it was my transfer case and not the tranny, so i decided to drive it untill it goes. Now that i know its both my tranny and my transfer case making the noise, and it comes in and out of o/d occasionally on highway. always making a whining sound regardless though. my tranny fluid looks fine and isnt burned at all. i am not very good with internals on the transmission so i want to avoid a rebuild. either put in one from the junk yard or is there i way just to replace the o/d unit without taking the tranny completely apart? also do certain year trannys have less problems than others?
Old Sep 16, 2010 | 04:54 PM
  #722
bigwill1767's Avatar
bigwill1767
Originally Posted by MonteC
I would start with the basics. This is an unknown truck. You need to see what kind of condition the transmission is in. Only way to do that is to drop the pan.
Also, if you hear a grinding noise when you go from a drive gear to park it sounds like the out put shaft is turning, but no power is being transferred. The noise could be the parking paul being ratcheted rapidly until the parking lugs slow down enough to en gauge. I would also drain the T case and check the fluid. You might find you have a band t case.
Friend dropped the oil pan said transmission looks ok. Replaced fluid/filter and speed output sensor. Picked truck up again today and drove about 5 miles and it quit again. Called wrecker etc. AGGREVATED.
Was driving and truck just lost all power. After stopped, I tried all gears, 4H,4L, 2L and nothing. When I put back in park it would whine and sorta grind again. Once in park it would continue to roll downhill. Park not engaging. I have no idea what problem is.
Also what is band t case?
Thanks for your help
Keven
Old Sep 16, 2010 | 11:00 PM
  #723
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
^Bad tcase. Typo.
A bad transfer case MIGHT cause something to go bad. Make sure the tcase has enough fluid in it first, but you might as well dump and flush it anyway. Make sure something hasnt blown up.... (may have)
Old Sep 17, 2010 | 01:56 PM
  #724
pavement_hater's Avatar
pavement_hater
Not the greatest pic but I just did a fluid change and found this in the pan. So tell me the bad news.
Attached Thumbnails MonteC's Transmission Corner (For Info Only)-new-image.jpg
Old Sep 17, 2010 | 08:55 PM
  #725
MonteC's Avatar
MonteC
Originally Posted by redneck_ram
my tranny went. i bought a rebuilt one with 10k miles on it from a 98 1500 4x4. everything shifts smoothly but over drive. it doesnt go in. from what ive researched today there are 2 types of torque converters. locking and non locking. locking has 23 splines and non locking has 24 splines. could this be the problem or am i looking at something easier as a simple solenoid?
The governor pressure sensors changed in 2000. You have the wrong sensor for the trucks computer. Change it out and you will be fine.
BTW if the torque converter had the wrong spline count the truck wouldnt move.
Old Sep 17, 2010 | 09:02 PM
  #726
MonteC's Avatar
MonteC
Just take the o/d unit off the back of the transmission and replace the snap ring. All years have pretty much the same parts, not much is better from year to year.
Old Sep 17, 2010 | 09:04 PM
  #727
MonteC's Avatar
MonteC
Keven
Park IS engaging. If the truck is rolling when the transmission is in park that means the transfer case is in neutral. Sounds like your trans is fine but your transfer case is screwed up.
Old Sep 17, 2010 | 09:05 PM
  #728
MonteC's Avatar
MonteC
You are experiencing the same problem as DodgeMagnum318.
The o/d direct snap ring is broken. You can take the o/d unit off the case and replace that snap ring.
Old Sep 18, 2010 | 03:58 AM
  #729
redneck_ram's Avatar
redneck_ram
couple questions. 1. where can i get this/these parts? 2. how can i tell what t.c. i have whether its the lockup or non lockup? thanks.
Old Sep 18, 2010 | 08:41 AM
  #730
1. Dealership, or WITTRANS.com. They also offer a kit to 'upgrade' the sensor/solenoid to better GM style units.
2. If you have an original trans, you have a locking torque converter.
