MonteC's Transmission Corner (For Info Only)
Old Aug 7, 2010 | 07:46 PM
  #621
MonteC's Avatar
MonteC
Originally Posted by J415
Hey Monte, So I've got 2500 miles on the tranny that I rebuilt (you helped guide me threw it) with no problems...I think. So yesterday I was driving my truck on the freeway after a full tune up (it was misfiring bad), and when I was doing 70 mph I felt my hesitate then kept on going. As if it didn't catch a gear. All this happened in about 2 seconds. This happened before I rebuilt my tranny so I'm thinking it's an engine problem but I figured I'd ask you first in order to rule out the tranny. Thanks.
Sound like an engine problem. I get that quite a bit, usually with fords. Common for the coil packs to start screwing up and the customer only really notices the mis on the highway. They think its the transmission but in fact they had dead coil packs.
No coil individual coil packs on the dodges but you can still have an engine hesitation without a misfire.
Old Aug 7, 2010 | 07:49 PM
  #622
MonteC's Avatar
MonteC
Originally Posted by daytonadan89
all at once, no 3rd and no reverse. there was no slipping or noise when this happened. i just took off from a stop sign and no 3rd gear, tried reverse when i got home and no reverse
o/d is working but it is o/d + 2nd gear, not 3rd.
it has a shift correction kit, big oil cooler, atf+4, 2500 miles on rebuild i guess i missed something it was my first rebuild, 95 318 dakota 4wd 46rh
i am hoping i dont need to pull the trans again. thanks for the help
No third and no reverse. You have a problem with the direct clutches. They come on in reverse. Something in the valvebody or there is a problem with the direct drum.
Old Aug 7, 2010 | 07:51 PM
  #623
MonteC's Avatar
MonteC
Originally Posted by forever_dodge
My friend and I rebuilt it. He's a mechanic, has rebuilt transmissions but never really diagnosed problems on them I think. He's checking into the problem too, but I thought I'd go on here to see if an expert in the field knew anything different. So no warranty, were just working on it in his garage.
So since the tranny was shifting fine, you think it's something wrong in the actual case? What would cause the clutches to be engaged so often?
We were very careful with the clearance specs for the clutches. Any ideas on what could be wrong that would make it rub off so much friction material?
Depends on the type of frictions and fluid you used. Also what converter did you use? How well did you clean it?
Old Aug 7, 2010 | 07:53 PM
  #624
MonteC's Avatar
MonteC
Originally Posted by tybuff
thanks for the help. Another quick question, talked to the guy again and he said 46rh is the trans he has, not the 46re that from what i have read should be in the 1996. He says the 46rh is still bolted to his 1996 v6.
If this is infact a 46rh, then am i right in saying its not the original trans that came in the 1996 v6 ram? Further, is it still not compatible even if it is a 46rh.
Cheers
You have a v8 he has a v6 the transmission that is bolted onto his motor will not be correct for you motor. I would avoid doing business with this person, they are either trying to deceive you or the they are clueless to what they have.
Old Aug 7, 2010 | 07:56 PM
  #625
jKsled's Avatar
jKsled
brand new converter from torque converter 1 in california. the frictions were in the pro super kit from tci. fluid was atf +4.
Old Aug 7, 2010 | 07:58 PM
  #626
MonteC's Avatar
MonteC
Originally Posted by kejobe
MonteC,
I've read this entire thread and I'm just looking for confirmation. I have a '01 Ram 1500, 5.2, 46RE, 4x4, 109,000 miles. The tranny shifts fine (no slipping that I can tell), it's just the timing and it doesn't seem to "put the power down". Early shifts, hard throttle to down shift, seems to be slow off the line, etc. From what I've read this is common with Dodge. I'm going to be plowing this winter so I would like to "take care" of this and help it out. Please correct me if I'm wrong or missed something. New TPS, GM pressure control soleniod conversion, governor sensor, transducer, Sure Cure, fluid/filter (obviously), and removal of check ball in cooling line. Is there anything else I should look at doing or is any of this not really needed. As far as it feeling slow off the line I'm not familiar with Dodge so I don't know if it's tranny or just the way the 5.2 runs. I've only had this truck for about 2 1/2 weeks. Any help would be great. Thank you.
I would do everything you listed and then drive the truck. If it is still sluggish then i would invest in a HD RV converter from Precision of new hampton. Converters can make all the difference.
I put new converters in every rebuild id do, ive had customers that have owned trucks since they were new come back and tell me that the truck has NEVER taken off as good as it did after the transmission. The reason the truck was so sluggish off the line was the factory converter was just loose and sloppy. It will still work but not as effectively as a nice tight converter.
Old Aug 7, 2010 | 08:01 PM
  #627
MonteC's Avatar
MonteC
Originally Posted by DuexDrei
Hi All,
Okay I'm new here and forgive me if this has been covered but after exhausting the search feature and skimming endless pages of this thread i didn't find anything that matched my circumstances.
I have a 98 Ram 1500 4x4 with 149k miles 5.2 and if i'm not mistaken its the 46re trans, as for what the problem is i'll describe it to the best of my ability,
1st and 2nd shift good going 2nd to 3rd it starts to almost jump hesitate and grumble a little before it grabs 3rd but only when i'm not giving it much gas , if I'm accelerating hard 1-2-3 seem fine but it will just hold 3rd until it red lines if i let off the gas and let the rpm's drop all the way down then step on the gas moderately hard it will go into what seems to be a "passing gear" definitely higher than 3rd but not overdrive, then if i hold that "passing gear" until i get to at least 55mph ish and repeat the rpm down and moderate acceleration process it will jump up to that passing gear then drop down into overdrive but every single time i let off the accelerator i have to do that process of letting the rpms come all the way down again if i just let off the gas and then ease back into it it will just climb to 4k+ rpm and feel like its not in gear at all.
Also I'm not sure if this is related but there is a noticeable "whining sound" when i'm coasting at lower speeds only when overdrive is turned on.
Now it has the check engine light on and the code reads bad o2 sensor ( Its going in the shop Monday for that) and i only bought this truck 4 days ago and i absolutely love it other than this problem.
Any advise or suggestions would be greatly appreciated.
Thanks!
Well id start with the basics. TV cable, filter and fluid, band adjustment and go from there.
Old Aug 7, 2010 | 08:36 PM
  #628
J415's Avatar
J415
Cool. Thanks for putting my mind at ease. I just don't feel like dropping the tranny again. What a pain in the butt.
Old Aug 7, 2010 | 09:01 PM
  #629
kejobe's Avatar
kejobe
Sounds good, except that I'm a little confused about the converter. I looked at Precision of new hampton's site to get a little info on the HD RV converter. Now, unless I'm missing somthing, they say the HD RV lowers the stall about 400 rpm. Shouldn't the stall be raised so that the motor gets into the power band? Or, am I misunderstanding something?
Old Aug 8, 2010 | 05:01 PM
  #630
DuexDrei's Avatar
DuexDrei
Thanks MonteC, alittle fine tuning of the TV cable and she shifts like new, you just saved me unknown $$$$ at a transmission shop.
Cant thank you enough.
