passenger side wet
Old May 26, 2010 | 09:33 PM
  #31
dhvaughan's Avatar
dhvaughan
Originally Posted by dhvaughan
3rd brake light ... or ... stopped up or cracked seal in AC drain to firewall. poke it out with a wire.
seal around the tube on the firewall with RTV. and attach a 90* turn-down to get the condensation away from the firewall and the crack.
Old May 26, 2010 | 09:43 PM
  #32
If you wanna kill odors, just get some fabreeze..... Or, if you want to clean your carpets some, go to family dollar (dollar general??) and pick up a bottle of "Awesome". A little bit goes a long way, and the stuff most certainly lives up to its name. (great engine degreaser as well....)
Old May 27, 2010 | 12:02 AM
  #33
truegent81's Avatar
truegent81
yeah i tried to remove the tube extending from the firewall. i stopped after a while of wiggling on it bc i thought i was gonna break the plastic tube off. it juts out about an inch and has a soft, foam like circular seal around it at the base. mayeb the best way to mess with this is after moving the evap core. isnt this tube part of the core?
just to be sure, i stuck a coat hanger into the tube and it hit a hard surface (like a wall) about one inch deep..nothing clogging it
Old May 27, 2010 | 12:21 AM
  #34
RamSport97's Avatar
RamSport97
Why were you trying to remove the tube? You can and will break it if your not careful. You attach the 90 degree turn down on to that little drain tube. The foam circular seal is what you need to put some RTV on.
Old May 27, 2010 | 06:54 AM
  #35
dhvaughan's Avatar
dhvaughan
^ +1 STOP wiggling it before you break it.
the cracks in the soft foam is where the water is weeping back in.
attach a turn down.
rtv around the tube and firewall to re-seal it. use black color so it won't show.
Old May 27, 2010 | 10:45 AM
  #36
shadowdiver's Avatar
shadowdiver
Have the same problem witrh mine, either the a/c or heavy rain. Have to check it out. Thanks guys.
Old May 27, 2010 | 09:40 PM
  #37
truegent81's Avatar
truegent81
well i was wiggling it bc i THOUGHT i had to remove the piece and put in the turn down. i think i figured it out. got pics...simple pics but everyone loves a pic
went back to AZ and looked all over. found this PCV rubber 90* vavle in the OEM section. i didn't know if i needed a hard plastic or what...it seems like it should work
the sealant i used on the firewall...
here is the firewall after all...looks like it should work, hoping it will
Old May 27, 2010 | 09:46 PM
  #38
dhvaughan's Avatar
dhvaughan
perfect. now use the water hose and soak down the door and 3rd brake light and cowl area and make sure its not still getting wet inside.
Old May 27, 2010 | 10:57 PM
  #39
RamSport97's Avatar
RamSport97
There you go! Yeup, definitely keep hosing everything (except a/c drain hose) to see if your getting any water.
Old May 27, 2010 | 11:21 PM
  #40
truegent81's Avatar
truegent81
thanks..sounds good, will do.
