Something is wrong with my truck. I get bad gas mileage
Old Jun 3, 2010 | 12:14 AM
  #31
CPTAFW163's Avatar
CPTAFW163
The AC robs a lot of power and gas. A LOT. I would say about 3.5 MPG
Old Jun 3, 2010 | 12:30 AM
  #32
2001Ram's Avatar
2001Ram
REALLY? That much?
Old Jun 3, 2010 | 12:44 AM
  #33
CPTAFW163's Avatar
CPTAFW163
yeah. I am guessing that you were using the AC because San Antonio was probably a balmy 100 degrees today.
Old Jun 3, 2010 | 01:26 AM
  #34
99dodge318's Avatar
99dodge318
yeah it was at least 100 and it was so humid. lol
but anyways i drive around with the ac on and still get about 16 mpg.
but i do live near a bunch of hills and the speed limit is 55. so my truck pretty much idles doing the speed limit.
Old Jun 3, 2010 | 01:44 AM
  #35
CPTAFW163's Avatar
CPTAFW163
it is friggin weird. My 2001 is pristine under the valvecovers, and the plenum was perfect (I did put in the hughes plate).
But my truck says 9.8 MPG on the monitor when I am doing city driving. But, my drive to work is 3/4 of a mile away, and i have to turn 4 times to get there. THat is a lot of stopping and going. That kills gas mileage. My motorcycle is supposed to get 35 MPG, but I go through 1 gallon a week on my mile commute.
If you are not in OD a lot, you are gonna burn gas. Hills help though!!! I can vouch for that! you just have to gain speed on the straightaway and then ease off the gas a bit so the speed stays at one point, then don't push the gas as you go up the hill. You will go from 75MPH to about 55-60, but your truck will not try to work harder and burn more fuel.
Old Jun 3, 2010 | 12:06 PM
  #36
trptman's Avatar
trptman
The BEST I've ever gotten out of mine was just shy of 16 mpg on a 250 mile round trip almost all interstate highways at 65-70 mph.
usually for city driving I can't get any better than about 10.
in the winter those numbers are worse.
Old Jun 3, 2010 | 09:05 PM
  #37
rmay635703's Avatar
rmay635703
Originally Posted by 2001Ram
Well, I went to San Antiono today.. On the highway all the time and when I filled up I used 1/2 a tank. The RESULT!
13.5. Thats all highway. What a POS. Ok i will... wtf why is this in italics? I will drive like a normal Teenager lol.
Let me guess you were driving 70-75mph?
Anyway you will notice in my reply I don't say much about the highway, in reality our trucks do the best on low speed rural roads where you never have to stop or change speeds (except on hills), in other words at what ever speed your transmission goes into overdrive is where you will get the best "highway" mileage, usually between 35 & 45mph. (so long as you don't have to ever stop anyway)
So unlike in town where you DON'T drive like grandma on the highway you must drive like grandma because our trucks are as aerodynamic as a brick without wheels.
Occasionally if the wind is with you or if you can side draft a semi you can drive much faster and still get good mileage but normally you must be driving 55mph or less, unless you add a $60 aerodynamic angled cover over your bed then you could get 16 going 70mph and it really isn't that much work either.
Something else you likely know but don't probably like is that our trucks like slightly higher octane than the generic cheap crap, I rarely use it but when its on sale I have gained some FE with 89 octane.
And one tip, if you drive on the highway a fair amount, allow the truck to slow up going up hills (hold the pedal steady) On the other side allow the truck to slowly accelerate by slowly moving in the pedal as it speeds up. That method works at ever speed, never try to force the truck to go faster than it seems to "Want" to go.
And obviously if you can plan an extra 10-15minutes of time just drive slower and hold the pedal rock solid steady that is the best way to get 3-5mpg better.
Cheers
Ryan
Old Jun 29, 2011 | 12:34 AM
  #38
Dodgeaaron's Avatar
Dodgeaaron
ok guys I mist the 1st ? I have a 2000 1500 and I am pouring gas out my tail pipe when I get on it and with my 360 I want to get in to it but dang gas come on please guys help.
Old Jun 29, 2011 | 09:35 AM
  #39
Are you sure its gas???
Old Jun 29, 2011 | 10:31 AM
  #40
Annihilator_X9's Avatar
Annihilator_X9
It's probably water.
