Something is wrong with my truck. I get bad gas mileage
Old Jun 14, 2012 | 08:57 AM
  #61
bent-fender's Avatar
bent-fender
Death flash was dodges answer to an engine that didn't have a knock sensor, and exhibited lots of spark knock.... so, they reprogrammed the PCM to pull timing. (thus, eliminating spark knock, but, also robbing power.)
To get rid of it, get a tuner from Hemifever Tuning. (he is a member here too...) 265 for three canned tunes, 365 for custom. Canned tunes will be fine for a stock truck, with just bolt on mods.
265.00? right? Well I got 180 miles to my tank
Old Jun 14, 2012 | 09:49 AM
  #62
You have something else going on there then.... that is less than 10 miles per gallon..... (assuming a 26 gallon tank, if you have the 35 gallon tank, then you have a SERIOUS issue somewhere.)
Need to fix whatever is ailing it FIRST before you start adding tunes into the equation.
Old Jun 15, 2012 | 07:23 AM
  #63
bent-fender
Typo I got 280 miles to my last tank. An yes it is a 26 gallon tank. Haven't decided to ad any tunes to it yet but a slight HP increase would be nice.
Old Jun 15, 2012 | 10:37 AM
  #64
billcart's Avatar
billcart
280 a tank isn't that bad. Wait are you a 4x4 or 2x?
Old Jun 15, 2012 | 10:41 AM
  #65
stewie01's Avatar
stewie01
280 miles a tank isn't bad even for a 4x2, depending on driving circumstances.
Old Jun 15, 2012 | 11:23 AM
  #66
billcart's Avatar
billcart
I agree. I have 4.56 gears, no plenum fix yet, 315x75r16 tires, and put at least 45 miles of 4x4ing in the sand every weekend. I get around 245 per fill up and that is when the gauge is in between empty and 1/4 tank. Although the pump stops after about 21 gallons.
Old Jun 15, 2012 | 02:09 PM
  #67
bent-fender
It is a 2x4 and before the tune up I was hitting 310 to a tank.
Where can I ad a pic to the bottom of my posts?
I found where to ad a avatard but it wont let me.
Old Jun 15, 2012 | 02:12 PM
  #68
stewie01's Avatar
stewie01
You mean 4x2. 2x4 is a piece of wood. Seems zman told that to someone recently.
Under User CP, click Edit Signature. Add and save. For the avatar there are size limits but it's under User CP, Edit Avatar.
Old Jun 15, 2012 | 03:32 PM
  #69
krichards6405's Avatar
krichards6405
Old Jun 15, 2012 | 03:53 PM
  #70
crazzywolfie's Avatar
crazzywolfie
i think if you want to start tracking your gas mileage you should start a fuelly's account. i doubt in that 280 miles that you burnt through all your gas. i think you just need to keep better track of everything.
