Help with muffler removal
Old Jun 2, 2010 | 11:45 AM
tuski's Avatar
tuski
Default Help with muffler removal
So i want to get my Flowmaster 50 series off my truck and put something else on. But my problem is i can't get this sucker off. Is there any method that would make it easier, such as heat (i haven't tried this yet), i would rather not cut it off, but i guess could if i wanted to remove all the dual pipes.
Old Jun 2, 2010 | 11:52 AM
ryan0714's Avatar
ryan0714
heat will loosen bolts and nuts yes, just make sure u dont get it so hot u bend the nut instead of breakin it loose. and of course good powered air tools help. wosrse comes to worse. u could just cut the nut and bolt off and get a new clamp.im asuming u have it on with clamps since u said u cant get the nut off.
Old Jun 2, 2010 | 12:48 PM
The clamps crimp the steel where the pipe/muffler overlap as well. Heat 'em up nice, and try and rotate it it to 'reshape' the metal. (wear gloves..... heavy ones....)
Old Jun 2, 2010 | 12:54 PM
TheBigRedOne's Avatar
TheBigRedOne
Just cut it off. You will spend valuable hours of your life trying to get that crimped/rusted mess off. If you cut it off right at the muffler ends you won't lose much pipe.
Old Jun 2, 2010 | 01:02 PM
dodgeman52's Avatar
dodgeman52
i got my put on my a muffler shop and it cost me 25 dollars and it took them 10 minutes to do it. alot easier then trying to do it yourself
Old Jun 2, 2010 | 04:46 PM
tuski's Avatar
tuski
Yeah, thats not a bad idea. Thats what i did to have it put on. I could just let em put on the new one and finish with whatever pipe is left over.
Old Jun 2, 2010 | 06:27 PM
barrypotts1b's Avatar
barrypotts1b
25 bucks to have a shop put the muffler on?
Old Jun 2, 2010 | 07:08 PM
dodgeman52's Avatar
dodgeman52
yea. they also do good work
Old Jun 2, 2010 | 07:55 PM
tuski's Avatar
tuski
i'm thinking of getting a Dynomax muffler, they sound pretty awesome (at least on their site)
Old Jun 2, 2010 | 09:40 PM
dodgeman52's Avatar
dodgeman52
why are u getting rid of the 50 series flowmaster?
