Baffled, wont start.
Old Jun 25, 2010 | 07:39 PM
Mowhawk's Avatar
Mowhawk
Default Baffled, wont start.
Got back from a week long trip to vegas.
Before trip truck ran fine.
Come home try to start her and got one crank then nothing.
Engine wont turn over at all, turn key and all i can hear is the starter clicking.
Fuel pump works, battery seems fine. Have full electrical, lights etc..
Just to make sure i tried to jump my truck and got the same results.
Wacked the starter motor a few times, and still nothing.
Im at a loss.
Can i haz help noaws?
Old Jun 25, 2010 | 09:16 PM
Load test the battery. It takes a LOT more power to crank over a V-8, than it does to run a headlamp.
Just as a test..... turn the key to the on position, and see where your voltmeter is sitting. Should be at LEAST 12 volts. What does it drop to when you turn on the headlights?
Old Jun 25, 2010 | 09:31 PM
zje400ex's Avatar
zje400ex
Is the starter making a clicking noise? I had the same problem as you and I first thought it was the battery but ended up being the starter. It's super easy to change the starter in these trucks. New ones run around $100 or so.
Old Jun 25, 2010 | 10:00 PM
dhvaughan's Avatar
dhvaughan
something drained your battery while it was not running for a week.
might be security, remote start, radio, etc
might be just a weak battery. try charging it up. it might/might not get over it.
one day the wife called from the grocery store and said the car wouldn't start. just clicked... i went up there and put jumper cables on it, no help. left the cables on for a long time and rev'ed the truck, no help. tapped on starter, no help. turned on headlights and had light, but the headlights died when hitting the starter. battery was about 4 years old, which should have been ok - but wasn't. it just decided to lay down and die. new battery fixed it.
Old Jun 25, 2010 | 10:30 PM
Mowhawk's Avatar
Mowhawk
Ill recheck the battery, its a new battery though. Only a year old, lights dont dim at all or anything when theyre turned on.
Battery reads at 12.4 (using sct tuner).
Cant hurt to throw it on the charger. Will post in the morning whats up.
Old Jun 25, 2010 | 11:29 PM
bigslick050's Avatar
bigslick050
If the battery is all good then prob try a new starter next? just my .03
Old Jun 25, 2010 | 11:34 PM
CPTAFW163's Avatar
CPTAFW163
you can get it tested at an autozone or advance. But then again, you need to get it there. Walking with a 40 lb weight is not too fun especially you are Air Force ROTC, can't you get a jet to fly you where you need to go :P
Old Jun 25, 2010 | 11:39 PM
Mowhawk's Avatar
Mowhawk
lol Ill have you know we have ruck marches . That and im a powerlifter
U army guys....lol
Old Jun 25, 2010 | 11:45 PM
CPTAFW163's Avatar
CPTAFW163
U army guys....lol
I knew some powerlifters. They were horrible on ruck marches. 20 miles carrying 45 lbs was too much for them. I know ROTC ruck marches. They were 4 miles at best.
Pilos don't need to march a while. They just need to know how to hide until the special forces extracts them.
BTW, what weight class? My good friend was national champ at the 125ish lb weight class. i think it was 126. But we said it was a fluke. Only one other guy qualified, so he beat one person for the crown.
Old Jun 26, 2010 | 12:15 AM
Mowhawk's Avatar
Mowhawk
national champ for 198 class, and then moved to 220 for a few state champs.
my goal is pararescue. We'll see
