A-Pillar Gauges
Old Jul 10, 2010 | 06:58 PM
  #31
Originally Posted by TheBigRedOne
Oh yeah.
Ok, and what is your reasoning for that assessment?
Old Jul 10, 2010 | 07:02 PM
  #32
TheBigRedOne's Avatar
TheBigRedOne
You replied while I was adding to my post. Jump back a page.
Old Jul 10, 2010 | 07:28 PM
  #33
Got it. Thank You.
Sound reasoning. These trucks aren't exactly designed to support the full weight of a rolling (as in, moving....) truck on the roof. Especially if you roll more than once......
Old Jul 10, 2010 | 11:23 PM
  #34
J McWillis's Avatar
J McWillis
Not to start a fire here, but on the older trucks (97 and earlier) the belts are mounted to the cab, not in the seat. The newer models are integrated in the seat to allow the quad cab rear doors to open since 97 and older CC's didn't have rear doors. Being as RM has a 96, if he's not running a harness he's probably using the factory belts.
Old Jul 11, 2010 | 01:20 AM
  #35
RM_Indy's Avatar
RM_Indy
Originally Posted by ryan0714
ok fine ill freakin see if i can find shop to weld it in real fast. i wish i was at home in oklahoma where i could do this all myself grrrrrrrrrrrr but i did buy the gauge and pod last night, got the single pod not the whole a-pillar, with the autometer ultra-lite trans gauge. should look pretty sweet.
Glad to hear your doing it right & welding it!
So your going with the column pod?
Knowing if your going 0-25mph is over rated
Trying to keep on topic but,,,,,,,,,
McWillis is correct, that is what I am using, factory belts that are mounted to the cab.
I do have a pair of harness's, just not in the truck
Still debating the whole bar, cage or neither, not sure if I can cut her up.
Old Jul 11, 2010 | 04:28 AM
  #36
TheBigRedOne
Good to know you aren't using harnesses with no cage. Cage or nothing.
Old Jul 11, 2010 | 05:15 AM
  #37
ryan0714's Avatar
ryan0714
Yea im gonna get it welded in, or at least try, and no i got the single pod that goes on the a-pillar but its not the full a-pillar its just the partial. i dont like the look of havin one on ur column.
Old Jul 11, 2010 | 06:33 AM
  #38
ryan0714's Avatar
ryan0714
another question, if i wanted to install a differential temp gauge, i just do the exact same thing and buy another bung fitting and have it welded in? and if i do buy this 2nd gauge im gonna get the dual gauge pod, so would anyone wanna buy the single pod from me?
Old Jul 11, 2010 | 10:04 AM
  #39
You will have to drill and tap the diff, or the cover, for the sending unit for that gauge.
Old Jul 11, 2010 | 10:34 AM
  #40
RM_Indy's Avatar
RM_Indy
I installed a 2gauge pillar pod first, month later had the 3gauge pod.
You shouldnt have any trouble selling the single pod
