cooling mod for the 408
Old Jul 30, 2010 | 10:35 PM
  #21
Laramie1997's Avatar
Laramie1997
Mod card: Everyone take a friggin time out!
An E-fan can help in a lot of ways. Never forget. It's just up to you if you want to do it or not. Yes a clutch fan is parasitic, but IMO it's a good mod to do on these trucks. Early 345 Hemi's were clutch fan powered as well and they see a good 10HP gain just from the fan's removal. With motors that are as LOW powered as they are, then yes, they will help. Not a lot, but a little bit.
Old Jul 30, 2010 | 10:44 PM
  #22
lane's Avatar
lane
Originally Posted by FarmBoy428
babyhuey defending his shiitty old clutch fans, cant spend $275 for some e-fans lmao.
heres a couple things i took from one of your posts: "I got money from my dad" and "my dad takes car of my insurance". So do you have $275 to buy buy some e-fans? or does daddy?
edit: sorry laramie posted before i seen that above.
Old Jul 30, 2010 | 10:46 PM
  #23
Laramie1997
Lane, what did my post say?
Stop inflaming or this thread will be closed down!
Old Jul 30, 2010 | 11:02 PM
  #24
aim4squirrels's Avatar
aim4squirrels
Old Jul 30, 2010 | 11:20 PM
  #25
J415's Avatar
J415
Jbomb, how much did you pay for the fans?
Old Jul 30, 2010 | 11:22 PM
  #26
Originally Posted by dodgeman52
i would think a 408 would make a lot more heat then what a neon fan could cool
My thoughts exactly.
Old Jul 31, 2010 | 12:04 AM
  #27
J415's Avatar
J415
^ Well a good rule of thumb is that the car/truck that you pick up the e fan from should have the same amount of cylinders as the car/truck your installing it on. Take, for example, an e fan I pick up when pick n pull had there half off sale. I got a dual fan off of a big V8 Regal. That way, I have a better chance of being as close as possible for my CFM needs, if not on the money. (It's damn near impossible to find out the CFM's of these fans)
Old Jul 31, 2010 | 01:13 AM
  #28
jasonw's Avatar
jasonw
Site Moderator
Its also nearly impossible (without measuring yourself) to determine the amp draw of the fans. Some of those fans pull a lot of power. Not sure how much that Regal's fans draw, but I'd be cautious myself.
Old Jul 31, 2010 | 01:34 AM
  #29
J415's Avatar
J415
As far as the amps are concerned, I guess I could just check out what the Regal was working with (stock). I haven't put them in yet, but I felt that I needed to get them since it was half off...I had to get them just based on principal alone. It'll be a while before they get installed, if at all. I just might sell them. They fit our rads width wise and are 3 inches shy of fitting height wise. I like to keep things looking as stock as possible.
Old Jul 31, 2010 | 08:13 AM
  #30
jasonw's Avatar
jasonw
Site Moderator
And they may work perfectly, I have no clue, I just mentioned the amp draw as a cautionary note. I remember aims4squirrels mentioning the amp draw for the Taurus fans, and the Lincoln mark fans as well. I can't remember the amount, but it was pretty high, 30A or something, where as aftermarket fans draw much less and deliver almost the same results (but are much more expensive).
Let us know if it works out for you.
The Black Magic fan I have, since it is inside the factory shroud, looks factory. 18A draw.
