Broken plenum stud help
Old Sep 27, 2010 | 10:31 AM
  #31
sungod's Avatar
sungod
You could probably get away with leaving it off. On mine when I replaced it my bolts were broken off. I thought it was a stud sticking up. I was afraid when I saw that it might be cross threaded, but luckily it was just broken.
Old Sep 27, 2010 | 11:36 AM
  #32
zman17's Avatar
zman17
Retired Moderator - RIP
Only if he wants to take it off again after the motor get's to operating temperature a couple times and the coolant start's spewing out.
Or God forbid, the intake cracks when the bolts are being torqued.
Old Sep 27, 2010 | 12:07 PM
  #33
Gary-L's Avatar
Gary-L
Veteran: Navy
Hit it with an axe!
Old Oct 3, 2010 | 04:41 PM
  #34
dhvaughan's Avatar
dhvaughan
i wonder how this turned out. TTT
Old Oct 3, 2010 | 05:33 PM
  #35
zman17's Avatar
zman17
He probably got so pissed off that he finally
Originally Posted by VWandDodge
Hit it with an axe!
Old Oct 3, 2010 | 11:16 PM
  #36
littletunny's Avatar
littletunny
Hey guys.
Boy the broken bolt from hell. Anyway I ended purchasing a flux cored welder from Harbour Freight. I could never get the nut to stay on to help remove the bolt. Then my coworker had a better idea of welding a new stud to the old bolt. Well it looked great but the stud/weld couldnt handle the 12 ft/lbs torque and ended up breaking.
Sooo everything is reassembled minus the fan shroud and I need to add radiator fluid. I will fire her up tommorrow.
So the bolt won. I am not worried too much. The other 11 bolts were torqued down hard. If anything it would be a coolant leak. There are 6 bolts on each side of the plenum. The middle 4 close off the 4 injectors, the last 2 close off the raw water passages (two total per side).
That bolt put me back a week!
Wish me luck!!
Old Oct 4, 2010 | 09:03 AM
  #37
sungod's Avatar
sungod
Mine had obvioulsy been broken for quite a long time with zero ill effects. I am sure there is the possibility of what you are saying happening, but there is a difference between theory and reality.
Old Oct 4, 2010 | 08:27 PM
  #38
littletunny
It runs like a scalded dog! No leaks!
That old plenum gasket literally crumbled when I pulled it off.
MPG went from 10,11 to 14 MPG (if the computer) is telling the truth.
Cool!
Old Oct 24, 2010 | 10:23 PM
  #39
micgolub's Avatar
micgolub
Default My bolt broke also
What do I do, if I want to remove the head?
Old Oct 25, 2010 | 03:46 AM
  #40
Sixtysixdeuce's Avatar
Sixtysixdeuce
In the future, smack the protruding stud with a ball peen hammer (authoratively, but not retarded hard), then let it soak awhile with PB Blaster. See if it wiggles. If not, continue rapping on it a bit, maybe soak longer. Still no movement, apply heat (mapp gas or oxy-acetylene; just don't melt it with the O/A torch), and tap it while it's hot. I've not had too many bolts I couldn't extract with those methods.
