Proper Borgeson Shaft Installation
Old Sep 29, 2010 | 10:34 PM
jor's Avatar
jor
Default Proper Borgeson Shaft Installation
96 2500, V-10
I just installed the Rock Solid Ram Truck Steering Fix bushing deal. Anyhow, I'm going to put it back together tomorrow and got to thinking about the Borgeson shaft that I installed earlier. Someone posted that the intermediate shaft should always be able to telescope like the original shaft. The Borgeson comes with a lock ring which I locked in place right at the intersecting point of the two shafts, making them effectively one shaft. Is this incorrect? Thanks.
jor
Old Sep 30, 2010 | 07:58 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Install it with the lock ring(as the direction say). Trust me, if you get in a crash it will slide.
Old Sep 30, 2010 | 08:09 AM
charlie1935's Avatar
charlie1935
Sounds like you had first hand experience.
Old Sep 30, 2010 | 08:26 AM
zman17's Avatar
zman17
No I have not thank God. I just know all that holds the ring is place is a small set screw .
Old Sep 30, 2010 | 09:08 AM
jor's Avatar
jor
Mine didn't come with any directions. (I ordered it off of eBay). I see your point about the set screw, however, I was referring to normal driving. Another poster had mentioned that the shaft should be free to slide as there was movement between the cab and the steering box. I've had lots of trucks with a solid shaft. Just wondered. Thanks.
jor
Old Sep 30, 2010 | 09:40 AM
There shouldn't be much movement.... unless your body mounts are rotted out. Installing as you have, should be just fine.
Old Sep 30, 2010 | 02:34 PM
zman17's Avatar
zman17
You don't install the lock ring tight to the outer shaft. All you do is push it up until it touches the rubber boot.
Old Sep 30, 2010 | 02:47 PM
zman17's Avatar
zman17
Her you go, hope you can read it. If not I'll try taking another one.
Old Oct 1, 2010 | 11:22 AM
jor's Avatar
jor
Default Thanks
Zman, thanks a million for those directions. They clear up two issues for me.
First, the one that I have been posting about re placement of the lock ring. I'm going to slide it down a bit today.
Secondly, one that has been bothering me on the Borgeson. I noted when I installed it that it didn't fit the stock setup exactly. i.e. the column end fit on the column shaft properly but then the bottom end (to steering box splined shaft) didn't line up on the shaft flat spot. I thought maybe it was assembled improperly or something. Anyhow, I simply tightened the allen screw onto the shaft where it hit. Now I see that I just need to create a flat for it so I'll do that too. Amazing what some instructions can do!
I test drove it around the block yesterday after installing the Rock Solid bushing and noted that it is probably 80% improved in the clatter. There's still something going on down there so I remain on the hunt.
jor
Old Oct 1, 2010 | 11:29 AM
zman17's Avatar
zman17
Glad I could help. Now check the lower shock bolts.
