how does this 360 short block sound?
#32
Yep, building motors is just not a cheap endeavor.
You would have to ask them about the heads, it is possible to hog them out for larger valves, but, given that the stock heads tend to crack between the valves seats anyway, I would see that option as nothing more than a recipe for disaster.
I wouldn't use the stock heads on a new rebuild anyway. There are lower cost alternatives for good heads. Clearwater has better design stockers (1.92 valves) for under 300 each. You would have to call and chat with 'em about anything meaner, as their online store just is NOT very informative. They have "monster magnum" heads for 475 each, but, zero information about what makes them "monsters".
As for horsepower estimates..... all depends on what he is using for intake and fuel management. Those are baseline numbers only, and to be taken with a grain of salt...... He was probably using a single plane manifold, and a big carb..... NOT what you are going to be running........ you will probably not make the same numbers as he advertises......
#33
#34
i found a 408 stroker on craigslist, it was built by a local machine shop and has been sitting in a 95 dodge dakota for about 1 year or so waiting to be fully assembled and hooked up by the owner who is in the military. the owner no longer wants it and is selling it for $1500, he said he has all the paperwork for it. should i be concerned with rust or anything? he said it has been filled with oil the entire time and cranks over just fine. good deal or bad idea?
#35
#37
#38
#39
#40
