Old Aug 5, 2015, 12:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: 4WD
Print Wikipost
Pulled My Transfer Case (Pics)
Old Nov 4, 2010 | 01:14 PM
^Considering the 231 and the 241 are very similar, I would assume yes, it would work.
A 241 is a 231 with beef'd up internals IIRC.
When mine go's, thats what I'm getting, a 241.
Looking at the pictures in the service manual..... yep, looks awfully similar. Guess I need to check that.....
Old Nov 4, 2010 | 04:42 PM
mrfarrell's Avatar
mrfarrell
I see your problem...the green tray's are for coolant not atf...
Old Nov 4, 2010 | 05:16 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by 95RAM360
i do plan on getting the saver, but can anyone tell me if they see where this snap ring is supposed to be? i have a feeling thats the problem that started this all.
and i work 11-11 today, and my weekend is booked.....i dont get my new t-case until next friday (my buddy is letting me make payments on it) so im going to fully gut out my case monday or tuesday....got to dark out last night....so ill have more pics to come....
You were told the snap ring was what happened, and if you plan on rebuilding yours, I hope you'll be getting a manual or a DIY somewhere. And the transfer case saver has directions as to where it goes. So what is the importance of knowing now? You'll need a lot more info from a manual or DIY. Or are you just going to wing it? LOL
I know the Transfer Case Saver will NOT work on a 241HD. The tail shaft is not removable. It has snap rings that hold it on from inside. So even though it has 4 bolts, it will not work.
Old Nov 4, 2010 | 05:47 PM
95RAM360's Avatar
95RAM360
the fluid level was very low, when i separated the case, only a quart and a half came out abouts....
I have a new transfer case, and i went today to find out that it is a 241...he told me the tag said 231....but i heard the splines are different with the 241...is this true? If not looks like i got a good T-case going in
Also i AM going to get the t-case saver for my 231....im rebuilding it over time....im just gutting the entire thing right now.....it needs a new casing, so i might not be able to rebuild it....
Old Nov 4, 2010 | 06:07 PM
zman17's Avatar
zman17
It's not a direct swap. I would stick with a 231 if I was you.
Old Nov 4, 2010 | 06:11 PM
merc225hp's Avatar
merc225hp
Have a look at the info on this site. I think you will run into drive shaft length issues front and back. The 241 is 2.58 longer and the output for the front shaft is further forward.
http://dodgeram.org/tech/specs/tranfer_case.htm
Old Nov 4, 2010 | 06:23 PM
95RAM360's Avatar
95RAM360
crap.......i might not be able to get this now....wtf....
luckily i did see a 231 on car-part for $200 with 91K.....
Old Nov 4, 2010 | 06:37 PM
zman17's Avatar
zman17
What do mean "WTF"? If you did some research before hand you would have known. Not only do I have a brand new TC saver, but I also have a 231hd transfer case that I spent 600 dollars to replace, in my 98 that has a clunk when in 4x4 when put in reverse, (which is why I bought the TC saver) but the truck got wrecked before I had the chance. But after the door debacle with you, I'm not even going there!
EDIT, and yes I still have the truck with the TC and the doors.
Old Nov 4, 2010 | 06:48 PM
UnregisteredUser's Avatar
UnregisteredUser
A quart and a half is right on full in a 231.
Old Nov 4, 2010 | 07:50 PM
redheadhunter21's Avatar
redheadhunter21
WTF means "What The F^ck"
