e3 plugs suck
Old Nov 29, 2010 | 11:05 AM
  #21
talon6's Avatar
talon6
Originally Posted by VWandDodge
How much did you pay for the tool to reprogram the PCM so the timing can be adjusted, and where did you buy it?
lol...
Old Nov 29, 2010 | 11:10 AM
  #22
crazzywolfie's Avatar
crazzywolfie
it seems stupid that that you should need to adjust your timing to use a spark plug.
Old Nov 29, 2010 | 01:29 PM
  #23
aim4squirrels's Avatar
aim4squirrels
The SCT pro racer package should allow you to change that stuff, VW. No Idea what it runs though.
Old Nov 29, 2010 | 02:17 PM
  #24
Josh_Putman's Avatar
Josh_Putman
Some assembly required, offer void in Rhode Island, see a doctor if symptoms persist more than seven days.
If your erection lasts more than four hours, call your doctor.
  #25
justfrfun's Avatar
justfrfun
Ether you guys are Dumb or board. Cam crank correlation, Is timing. The computer can only adjust the timing so far. witch is set by where the distributor sets and the crank sensor. And correct me if i'm wrong dodge doesn't use a knock sensor as per chevy. At least i haven't come across any problem with knock sensor on a dodge to know if it has one or not.And yes, adjusting your timing for fuel,spark is part of "tuning" I believe. Hmm may be i'm just in the wrong forum...never mind I have to get back to doing head gaskets on a 90 chevy, then heads on a Azteck. It should be easy though sense theres no timing involved.lol
Old Nov 29, 2010 | 03:22 PM
  #26
Timing is determined by the crank sensor. Fuel injector timing is controlled by the cam sensor. (pick up coil) Moving the distributor changes when the fuel injectors fire, not when the spark plug fires.
And no, dodge doesn't use a knock sensor. I really wish they had....
Old Nov 29, 2010 | 04:36 PM
  #27
95Erokram's Avatar
95Erokram
I have no problems with e3's. Fell victim to bosch 4 prongs. Worst mistake ever. E'3 are helping with power. Mieage not quite sur though. Why is it that im a lucky one??
Old Nov 29, 2010 | 05:19 PM
  #28
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by justfrfun
It sparks way faster than a regular plug and makes a bigger spark.
It "sparks way faster"? What does that mean?
Old Nov 29, 2010 | 05:38 PM
  #29
zman17's Avatar
zman17
Retired Moderator - RIP
LOL
LOL
And, ROTFLOL
Old Nov 29, 2010 | 05:48 PM
  #30
dodgeman52's Avatar
dodgeman52
my e3s worked good for a while and then all of a sudden crapied out on me
