Old 08-13-2015, 05:52 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Removing Upper Dash?
Old 01-02-2011 | 05:56 PM
Prodirt6000's Avatar
Prodirt6000
Default Removing Upper Dash?
Hi Guys,
I'm trying to hide my GPS wire in behind the dash so when I have my Garmin up on the window (bottom left corner of my windshield) I can just have the USB end of it right there.
My plan is to wire up a 12V accessory plug in up under the steering wheel area, and have the Garmin wire go up thru the dash. Problem is, I cant feed it up thru there. I was wondering if I could just remove that top part of the dash, where the 5 screws are up close to the windshield. How difficult is it? Do you have to remove the trim face piece part? I have been searching on here, and I couldnt really find anything in my repair manual.
Any ideas or thoughts would be helpful!
Thanks,
Brandon
Old 01-02-2011 | 06:09 PM
Not without its hazards.... Getting it off without it deciding to blow itself into several pieces can be a challenge. Might be more successful running it up along the trim panel down there, and then between the dash, and the door seal? or whatever happens to be over there.
Old 01-02-2011 | 06:24 PM
BIGBIRD85's Avatar
BIGBIRD85
there are screws under the dash that i broke off when i tried that VERY SAME THING. my dash is now in pieces. anyone here know where i can get one online?
Old 01-02-2011 | 07:22 PM
Prodirt6000
Uh oh! I think I'm going to stay clear from that!
Old 01-02-2011 | 07:58 PM
dipsherry's Avatar
dipsherry
yeah my dash blew apart and now looks like a jigsaw puzzle when i tried to take it apart to run some wires behind the dash. I decided to just get a dash mat to hide its lovley looks and i ran my wires under it lol
Old 01-02-2011 | 09:00 PM
edlucky1's Avatar
edlucky1
If you have several people its not hard if you take your time. I had to replace my heater core last year and me and my brother did it by ourselves. If you decide to you should check your core and any other parts under there because you won't want to do it again a few months down the road.
Old 01-02-2011 | 09:57 PM
krs7272's Avatar
krs7272
Problem is the screws you see at the base of the windshield are not the only ones. There are also 4-5 additional screws that are screwed in pointing toward the driver that facilitates removing the dash to access.
Old 01-03-2011 | 08:36 PM
mr freeze's Avatar
mr freeze
This is what mine looked like when I removed it.
Your results may vary.
Old 01-03-2011 | 08:37 PM
Ooooooo..... JIGSAW PUZZLE!!!!
Old 01-03-2011 | 08:56 PM
Prodirt6000
Mr Freeze thank you for that picture.............I am definitely NOT going to try to take it off. Mines got no cracks and I'd like to keep it that way!
Quick Reply: Removing Upper Dash?
