Torque converter not locking?
Old Mar 5, 2011 | 09:18 AM
Novarider's Avatar
Novarider
Default Torque converter not locking?
I think my torque converter isn't locking. With OD off it shifts 1st, 2nd 3rd then nothing even at 60mph. With OD on it shifts 1st, 2nd, 3rd, 4th(OD) then nothing even at 65mph. What could be causing this? A bad torque converter or maybe just the solinoid?
When I bought the truck (last week) it had a check engine light so I took it to the mechanic and he said it was a TCC(torque converter clutch) code. We didn't do anything because neither of us know the truck. I have put 300 miles on it since then and the check engine light has not come back on.
I really hope the transmission isn't bad. I don't have $2000+ to put in this truck!
The pan gasket is leaking and I plan on replacing it this weekend. Could that be causing the problem? I checked the fluid level yesterday and it was fine.
Old Mar 5, 2011 | 10:46 AM
J415's Avatar
J415
So with the OD on, the RPM's don't drop when it's going into 4th?
Old Mar 5, 2011 | 10:52 AM
Novarider's Avatar
Novarider
Yes it drops when shifting into 4th but isn't it supposed to drop again when the converter locks? When driving at 55-60 the rpm's are at 2000-2200 isn't that higher than it should be?
Old Mar 5, 2011 | 12:08 PM
J415's Avatar
J415
That's exactly where mine are. 2k-2,3k
Old Mar 5, 2011 | 12:15 PM
Novarider's Avatar
Novarider
Ok but shouldn't the rpm's drop when the converter locks? When I have OD off it goes 1,2,3 then nothing no rpm drops after that
Old Mar 5, 2011 | 12:22 PM
J415's Avatar
J415
What CEL did the mechanic pull when he ran it for codes? Did you replace the TCC solenoid? That could be your culprit. It controls the shifting of your OD unit.
Old Mar 5, 2011 | 12:31 PM
Novarider's Avatar
Novarider
No we didn't replace anything and the code had not come back up. He didn't want to replace it because neither of us know anything about the truck because its new. It threw a TCC code and thats it
Old Mar 5, 2011 | 01:49 PM
99dodge318's Avatar
99dodge318
id get a new mechanic! these trucks are 10+ years old, and there are literary thousands of them out there.
Old Mar 5, 2011 | 01:54 PM
Novarider's Avatar
Novarider
What does that have to do with anything? I know there a lot of these trucks I see them everywhere.
Old Mar 5, 2011 | 06:05 PM
Novarider's Avatar
Novarider
Could this be it?
http://dodgetruckworld.tenmagazines....c.asp?id=61247
