backglass slider question
hey guys, my slider glass in my truck has had a broken panel since i bought it. i found one for dirt cheap, but its from a '96. so my question is.... would a slider from a '96 fit into an '01? reason why i ask is because www.car-part.com says only sliders from 98-02 will fit. just want to make sure a 96 window will fit. thanks guys!
There are a couple different flavors of rear slider in the second gen trucks.... I have seen at least two different types, and that was in the junkyard...... If they both are the same style.... it might work. (if you just wanted to change the glass.) If you want to change the whole thing..... I don't think the window opening changed at all..... Check with LMC truck for verification before spending money though. (or, your local dodge dealer.....)
If you dont want the slider anymore, I got a price from a local glass shop for a new solid window: $350 installed. I'm still waiting for aftermarket to come out with a 3-piece window to replace the horrible 4-piece.
A window from a '96 should fit in your '01, although it will have the uglier black trim around it.
