End-all Be-all plenum thread
Old Oct 3, 2011 | 12:19 PM
  #121
Archion's Avatar
Archion
Originally Posted by Tazman89
Well I did it! the plenum is in no broken bolts all sensors are back together and it is running fine but now I have a check engine light on so tomorrow im gonna have it scanned and see what it is!
If you have a digital odometer, you don't "have" to take it to be scanned, you can use the built in diagnostics that Chrysler was nice enough to leave in from the old OBD I days. Cycle the ingition key three times without starting, and leave the key on the third time. It should read out the p-codes on the digital odometer if you were succesfull.
There is a lot of great info in this thread. I just picked up the 99 in my sig for my GF. Gonna bust out the old magnet to check this out later. 200k and runs great, new trans. I know the truck has had the cats replaced recently by the dealership, along with the rest of the exhaust, so the plenum is on the list of may need to do's.
Old Oct 3, 2011 | 01:06 PM
  #122
Wh1t3NuKle's Avatar
Wh1t3NuKle
Really? That is a useful tidbit.
Old Oct 3, 2011 | 06:39 PM
  #123
zman17's Avatar
zman17
Retired Moderator - RIP
Won't work on 98's for some unknown reason.
Old Oct 3, 2011 | 07:48 PM
  #124
Tazman89's Avatar
Tazman89
well got it scanned it came up as the iac so im gonna clean it tomorrow and see how that works and i also ran a can of seafoam through it and lol at the smoke show!
Old Oct 3, 2011 | 08:35 PM
  #125
zman17's Avatar
zman17
https://dodgeforum.com/forum/dodge-r...n-the-iac.html
Old Oct 4, 2011 | 06:30 PM
  #126
Tazman89's Avatar
Tazman89
Thanks zman but I already found it! ha lol well I cleaned it and that was it the truck runs great now!
Old Oct 13, 2011 | 03:21 PM
  #127
Bens5.9l4x4's Avatar
Bens5.9l4x4
Does anyone find it odd that im sitting at 199,486 miles still with the oem plenum and intake and have had no signs of damage? I did the magnet test and of course it stuck. I pulled the pre o2 cat sensor and will also test that way. I was just curious if this makes my truck out to be considered a ticking time bomb?
Old Oct 13, 2011 | 08:23 PM
  #128
Bens5.9l4x4
Pulled the o2 and no difference.
Old Oct 16, 2011 | 08:59 PM
  #129
Matt Nickerson's Avatar
Matt Nickerson
The only "test" you need to do, as the thread already suggests...Is to pull the TB off and look 360* around the intake for pooling oil. No need to pull the o2 unless you're checking for a clogged cat.
The "scientific" numbers say that 99.9% of 2nd gen rams are affected by leaking plenum (i just made that up)...you could be that 0.1% but I doubt it unless you've thoroughly checked the intake.
Opening the throttle plates isn't fully checking. I had to take the throttle body off to see the oil in the back of the intake.
Old Oct 21, 2011 | 01:27 PM
  #130
Crackshot's Avatar
Crackshot
Do the 2001 5.9's have this issue too?
