End-all Be-all plenum thread
Old Mar 2, 2012 | 12:52 PM
  #321
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by bosanci28
did yesterday the dry/wet compression test:
cil1 dry-150 wet-180
cil2 dry-157 wet-185
cil3 dry-157 wet-183
cil4 dry-150 wet-177
cil5 dry-150 wet-177
cil6 dry-155 wet-180
cil7 dry-153 wet-177
cil8 dry-157 wet-180
also based on this tread here
https://dodgeforum.com/forum/2nd-gen...ml#post2730486
had some problems with my engine cutting off ,found a bad crack sparg plug,replaced it and the truck works really good now,
thanks
regards,
bosanci28
Did you have all the plugs out when doing the compression test or one at a time?
Old Mar 4, 2012 | 04:27 AM
  #322
AquaRamMan's Avatar
AquaRamMan
Thanks for the thread about the plenum repair. I have been having all of these issues but just chalked most of it up to the auto tranny and old truck. Aside from the symptoms mentioned above, could this also cause an overheating issue? I replaced my water pump one year ago, thermostat within the last six months and had the cooling system flushed but to no avail, the truck still overheats. Now, while driving in the city I do drive with the O/D turned off, always turn it on for the highway. It overheats way faster with the A/C on of course... Any suggestions aside from replacing the heater core and radiator?
Old Mar 4, 2012 | 08:33 AM
  #323
Are you losing any coolant?
Old Mar 4, 2012 | 08:41 AM
  #324
zman17's Avatar
zman17
Maybe clogged radiator, bad fan clutch, radiator cap?
Old Mar 8, 2012 | 02:57 PM
  #325
AquaRamMan's Avatar
AquaRamMan
Not losing coolant unless I drive it hot and shut it off while it's boiling. Radiator cap is good, fan clutch I think is good, just had a coolant flush done. I have been smelling coolant when it gets hot lately but no leaks under the carpets or in the vents.
Old Mar 10, 2012 | 03:19 AM
  #326
Wurzberger's Avatar
Wurzberger
So Im just about ready to start putting it back together. My question is what does everyone recommend in regards to the gaskets and RTV. What gaskets, if any, should I use RTV on? I have a tube of permatex red rtv, should I pick up something else? Should I use any threadlocker or anti seize on any of the bolts?
One last question, in the countless pages I have read it seems the bolts to hold the plenum in are too long. Because of a tight budget I have decided to buy an intake gasket kit from the local auto parts store that includes all the gaskets and fresh new bolts. If the new bolts I got for the plenum are the same length should I grab some small washers for all the bolts?
Old Mar 10, 2012 | 09:46 AM
  #327
Fel-Pro gaskets.
Little bit of RTV around coolant passages. Not much though. You aren't torquing things that tight.
I used blue threadlocker on the plenum bolts, and that is the ONLY place I used thread locker.
If the bolts are the same length, some washers will solve that.
Old Mar 10, 2012 | 09:58 AM
  #328
bwdakrt's Avatar
bwdakrt
...and don't forget to put a medium sized dab of RTV in the 4 corners where the rubber gaskets meet the the fiber gaskets on the heads.
Old Mar 10, 2012 | 10:16 AM
  #329
Oh, yep. Can't forget that one. Thanks.
Old Mar 10, 2012 | 09:57 PM
  #330
candymancan's Avatar
candymancan
Guys what inch lbs torque wrench should I buy... Craftsman seem to only sell 25-200 inch lbs torque wrenchs, and same with harbor freight.. harbor freight does sell a 0-60 inch lbs wrench but dont the bolts need to be torqued up to 72 inch lbs in the end.. ??
So im wondering would the craftsman be ok to use ? Meaning torquing the bolts in sequence starting at 25 inch lbs vs 12 inchs lbs at a time ? I really need a answer for this.. Because no one seems to ever answer me on any forums when it comes to torque wrenchs when working on the plenum pan... I also cannot afford $$$ wrenchs.. I only make $8.60 an hour so i need to go with something that will work and is affordable
