End-all Be-all plenum thread
Old May 10, 2012 | 06:19 PM
  #401
DrkLink's Avatar
DrkLink
Talking
Originally Posted by 1999blkdakrt
Really? My plate is 60 bucks plus shipping versus 90 bucks plus shipping from hughes, that's 30 bucks right there, that is your oil change and your coolant needed for the intake plate replacement. Every auto parts store I have gone to always has the preferred Fel-Pro gasket on hand, never have had to order one and wait.
I would offer a package with the gasket set but do not see the point as you can get it for the same price I can and I would have to increase shipping costs do the the larger packaging and added weight.
Just wanted to say THANKS for the plate I ordered from you!! It looks real good and it actually came before the estimated delivery date! I'll install it this weekend when I'm off from work... again... THANKS ;D
Old May 11, 2012 | 08:32 PM
  #402
new2dodge2009's Avatar
new2dodge2009
Ok I am in the middle of tearing my 95 dodge 3500 with the 360. Intake is almost off. I have a metal line thats in the back of the intake under the egr valve that runs down to the exhaust manifold. cant seem to break it loose at either place any suggestions? And can I do away with that crap when I put it back together?
Old May 13, 2012 | 10:19 AM
  #403
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Prolly the EGR tubing. Most usually bypass it and block it off. I don't know the procedure for that though.
Old May 14, 2012 | 08:43 PM
  #404
new2dodge2009
Are the newer model (98-01) without EGR valves and if so will it interchange with my 95 model?
Old May 18, 2012 | 12:51 PM
  #405
acab247's Avatar
acab247
Looks like ill be needing to change my plate. Yay or nay?
http://www.youtube.com/watch?v=RPgkqoXahag
Old May 18, 2012 | 01:12 PM
  #406
Fair bit of crap, but, I don't see any oil pooling.... need to pull the TB, and have a look around.
Old May 18, 2012 | 02:15 PM
  #407
zman17's Avatar
zman17
Retired Moderator - RIP
+1.... as stated many times in this thread and others, looking down the butterflies is useless.
Old May 19, 2012 | 07:43 AM
  #408
bigram1997's Avatar
bigram1997
Finally got off my butt and installed my Hughes plate, while I was at it also changes my valve cover gaskets, the bolts on the covers were not even finger tight.. Had no problems and the entire process took about 10 hours. Thats including lunch and a couple trips to auto parts store. It was a hell of a lot easier than a heater core!!!!
1997 Dodge Ram 1500 4X4 360
162,000 fun miles
Old May 21, 2012 | 09:34 PM
  #409
DrkLink's Avatar
DrkLink
I replaced the plenum plate and gaskets about 2 weeks.. and when I turn it on it idles/revs on its own at 2 RPM I'm thinking there is a hose which isn't plugged in but from what I can see everything is plugged in right. There is also this burning smell... kinda "sweet" I was told that is the gasket sealing heating up... I haven't driven it since then and I don't know what's wrong... anyone have a similar problem after replacing the plate?
Old May 21, 2012 | 10:45 PM
  #410
You have a pretty serious vacuum leak somewhere, or, the IAC is stuck..... try cleaning the throttle body first, there is a DIY in the faq section for that. (I think.)
Check your oil, see what it looks like.... also, check other gasket areas to see if you are losing any coolant.
