End-all Be-all plenum thread
Old Jun 5, 2012 | 11:34 AM
  #421
DrkLink's Avatar
DrkLink
I was having stalling issues and "clanking" noises with hesitation when I accelerated. The other day I unplugged the eletrical socket off the front O2 sensor and that seemed to fix the issue. So my questiion is: is it the cat that is bad or the sensor... could it be both?
Old Jun 5, 2012 | 03:44 PM
  #422
If the sensor is still in the exhaust, and it runs better with it unplugged, that's more'n likely a bad sensor.
Old Jun 6, 2012 | 02:55 PM
  #423
zman17's Avatar
zman17
Retired Moderator - RIP
I hate to disagree, but, if the plenum is blown and the cat is clogged/clogging, of course it might run better with the o2 unplugged. Time to remove the TB and look and confirm.Other issues may be present, but one step at a time. (before the heads are not cracked).
Old Jun 6, 2012 | 04:14 PM
  #424
1999blkdakrt's Avatar
1999blkdakrt
Hate to burst your bubble but 98% of all 5.2/5.9 magnum series heads come from the factory cracked, they had a genius design that engine.
Old Jun 8, 2012 | 11:08 PM
  #425
Orion3974's Avatar
Orion3974
Besides paying too much for the hughes kit can anyone tell me what the two black peices are that are about 4-6 inches in length? They are on the top right side of the picture on their website . If I knew how to put the pic here I would.
Thanks
Old Jun 9, 2012 | 03:22 AM
  #426
bwdakrt's Avatar
bwdakrt
Thanks
Front and back gaskets. You'll need to put a small blob of RTV in each corner where they meet the side gasket to seal them up and prevent an oil leak.
Old Jun 11, 2012 | 03:21 PM
  #427
BamaRam97's Avatar
BamaRam97
Is this the appropriate gasket set for the Plenum fix? Autozone list two seperate Fel Pro ones.
http://www.autozone.com/autozone/par...47_288361_5297_
Old Jun 11, 2012 | 04:13 PM
  #428
bwdakrt's Avatar
bwdakrt
Yelp. You'll also need a tube of black RTV and I recommend a new bypass hose, new TB gasket and new fuel injector o-rings.
Old Jun 12, 2012 | 08:18 AM
  #429
BamaRam97's Avatar
BamaRam97
I was planning on just taking the fuel line apart and not removing the injectors. Isn't there a valve to seperate the fuel line and leave the injectors in the intake? I may take thte throttle boddy off. It needs cleaning.
Old Jun 12, 2012 | 09:05 AM
  #430
You can disconnect the fuel line from the rail, and just leave it in place. Careful with it though...... if you break it, they are fun to find.
