End-all Be-all plenum thread
Old Jul 10, 2012 | 07:34 PM
  #571
crazzywolfie's Avatar
crazzywolfie
this just popped up on another forum and i thought it was some good plenum info. how to test if your plenum is blown
Originally Posted by Captain Obvious
Yes there is a way to test. TSB instructs you to use a vacuum gauge on pcv breather line. A normal engine has positive crankcase pressure or blow by and will build pressure in the crankcase, which reads on the gauge. If it builds positive pressure at all, stop the test, it passed. If you don't stop the test by 3 or 4psi you will probably blow out the dipstick, oil pan gasket, or valve cover gasket.
An intake plenum leak will create a suction on the crankcase, and it will show up as vacuum.
The shadytree method is to just look for oil down the throttlebody. That works somewhat in "theory", but ends up causing owners to pull an intake they didn't necessarily need to. Often regular blowby pcv oil pools are confused for valley pan.
It is justifiable to pull it anyways if the heavy duty valley pan is to be installed, but not worth it if the crappy stock style gasket is replaced and tin cover reused. The cover itself is often the problem.
Old Jul 11, 2012 | 09:31 AM
  #572
It's Me Patt's Avatar
It's Me Patt
Right there. All four corners. The rubber gaskets go on AFTER the intake gaskets.
yeah so they hold them in position..was wondering how that worked out...as for the rtv, does it go under the cross over gasket ends?
Old Jul 11, 2012 | 09:51 AM
  #573
It's Me Patt
Also I bought the ultra black, hope that's right? Do I let it set up at all before I drop in the IM?
Old Jul 11, 2012 | 10:19 AM
  #574
It's Me Patt
And is there a known cure time (for the rtv) before I can run the truck?
Old Jul 11, 2012 | 11:28 AM
  #575
By the time you get it all reassembled, it should be cured enough to run it.
Old Jul 11, 2012 | 03:11 PM
  #576
It's Me Patt
Just got back from the auto part store. Read the back of the package and it states 24hrs for full cure. I ordered mine online and they put the shipping sticker on the back of the rtv package (that's why I didn't know..fyi)...but thanks...I guess I'm going to hit the four corners BEFORE I put the cross overs on...
Old Jul 13, 2012 | 07:42 PM
  #577
wjxavier's Avatar
wjxavier
you could always do both sides...that wont hurt it any. btw, got my intake manifold today, and the reason i ordered this one from ebay is because........it doesnt have a divider! bwahahaha! call me a lazy bastard, but i dont have to do THAT mod now lol
EDIT: got one question. theres a metal bracket with three bolts in the lifter valley that looks like its holding down the lifter sleeves? just wondering if its safe to take that off so i can clean under it, and if it is, what the torque of those 3 bolts are. thanks!
Old Jul 13, 2012 | 09:22 PM
  #578
It's Me Patt
To late, I just put it under the x over gaskets ends..so I'm sure you're talking about the piece that runs down the center of the valley. I don't know what it's called. If someone jumps in and gives me the name I can give you the torque spec...hope the pic helps identify it..
Old Jul 13, 2012 | 10:34 PM
  #579
wjxavier's Avatar
wjxavier
yep thats the one i'm talking about lol. has 3 bolts holding it in the valley. if its not a good idea to take it out, then i wont. i'm just being a picky, i like my stuff clean and i can see that its still got gunk under there that i can't get at with the vacuum lol
Old Jul 13, 2012 | 10:57 PM
  #580
It's Me Patt
TIP: Since you should remove your throttle body when doing the plenum job, ya mine as well do it right. Use 'throttle body/carb' cleaner' (remember some tb have a special factory coating which can be damaged if you use something else to clean it. Protect the sensors! Get a handful of q-tips and go to town. Remove & carefully clean the IAC..If you can afford it, replace it ($35-45) I spent $2.50 on the can of cleaner..
Before
After
Bottom
