End-all Be-all plenum thread
Tip: I numbered the bolts to keep track...Then with each pass I put a dot next to the particular bolt I torqued..the 1st pass was 12 in. lbs (one dot) 2nd pass 48 in. lbs (second dot) and so on...Helpful if you have short term memory issues, kids running around or the wife asking you to do ten other things while your torquing away...
Old & Crusty
New..Hughes pan
And don't forget to use BLUE LOCTITE on them bolts!
Old & Crusty
New..Hughes pan
everything looks good bud! thats what i've been doing all night is cleaning everything lol i've already got another TB that i cleaned up and did some mods to so its waiting to get wiped off and thrown on
i picked up some good engine degreaser. heavy duty gel stuff. thats what i used to clean my intake and holy cow did it work great! thing looks almost new! lol
TIP & correction: TB and/or the IM has has a coating that can be damaged! If you can pick up a IM or TB from the junk yard and clean and/or do your mods to before you start the plenum job, do so...98% of my time was spent on cleaning parts, running out to HD, advanced and napa...I had all the parts before I started the job but needed stuff like drill bits that weren't in my collection of like 150...heliCoil kits, new size IM bolt, general bs stuff...
Think I would be more tempted to just get some longer bolts, and use nuts on the bottom, since you can get to them..... can't leave the washer on top, as it would prevent the manifold from sitting correctly, and it would never seal. You would have vacuum, and coolant leaks..... not a good scene.
You might be able to get away with filling the hole with JB weld, and redrilling it in the correct position, tap it, and then helicoil, or not (tap to correct threads).... not like the bolts are torqued to huge values......
yes i only ported the very bottoms lol where the spray pattern actually matterns to a very small degree. like i said, might not do anything, but i was bored at 2 am lol
i'd really like to know about that plate in the valley as well! wish someone would chime in and tell us what the torques are for those bolts lol. or if its even safe to take off without screwing up something lol.
got another question to anyone who might be able to answer. the different IM i got to put on only has one water temp sensor port. my old one had two. one sensor has one wire to plug into, the other one has 2. which one should i use for it to work properly? whats the purpose of having two?
