While I'm at It...
Im currently in the middle of the same thing, I did the plenum fix from Hughes, modded intake, cut TB horns, 180 thermostat, front O2, and timing chain. I also went with a new cam (low end, towing type) from Hughes #9204 since is was an extra $100 after the core return. Hoping this will improve mileage a bit. "while your in there..."
I would also recommend a new coolant temp sensor since the fuel economy is also based on this (along with the O2 sensors). Also get a decent set of plugs while you're doing the cap, rotor, wires, coil...
I also had my heads off, and decided on rings and rod bearings. pan gasket had to be replaced when i pulled the timing cover off so again "while I was there..." Pacesetter longtubes going back on which are better than the manifolds, and getting rid of the restrictive factory Y-pipe. Your budget is always a driving factor but "while your in there..."
Ahhh, I see what happened: you are confusing the terms "throttle body" (TB) and "intake manifold"
Just for future reference, there is no such thing as an "egr sensor" (not to my knowledge, anyway) rather; EGR is an engine system that died with the implementation of OBD2 compliance mandate (or shortly thereafter)
EGR = exhaust gas recirculation... basically, exhaust was recirculated through the intake to reduce any unburned hydrocarbons. Its performance (and ability to set a CEL) was measured by o2/vacuum fluctuations and MAP/IAT input (that's how I understand it).
A throttle body has nothing to do with EGR, but the intake manifold does.
Short answer: 97 was a transitional year when some manifolds were produced with EGR, some without. here are some links to pics of Intake mani's with/without EGR ports:
With: (notice the doolamahicky on the top right hand corner of the manifold)http://cgi.ebay.com/ebaymotors/1993-...Q5fAccessories
Without: (has the hole, but nothing in it... best pic I could find):http://www.hughesengines.com/Tools/P...=HUG%205514-RA
So now ya know
I've never seen one of these trucks set an EGR code, but I know it's possible for it to happen on EGR equipped cars (through experience with other, older vehicles). The performance evaluation part was explained to me by someone with a wealth of knowledge on subjects such as these (my uncle)... he could have been wrong though.
That was my first thought on the matter as well, but all of the sources I could find state that it carried over as far as early 98, hence the EGR/non-EGR identification guide.
