rpm's jumping need help!
(i already posted this in the dakota section but just tryin to get as much help as possible since a lot of yall probley have the same motor, 5.9L automatic)
So my abs and brake light had been coming on so i was told to replace the speed sensor, did it. Weird thing though when the lights didnt come on id have random rpm jumping like the tps was bad. Well after replaceing the speed sensor i went ahead and put in a new tps yesterday. Well, i'll use today as an example, on my way to work my abs and brake light came on plus my rpms are still jumping randomly! On my way back from work the lights didnt come on but still had jumping rpm's. So now im worried either my tranny is randomly slipping or my map sensor is randomly telling my ecu to give it more gas due to my plenum gasket being bad (i checked it yesterday with the throttle body off and could see oil residue). So i guess i actually have a brake issue somewhere but im mostly concerned with the other problem. Also i checked my tranny fluid and it has about an inch and a half to much on the dip stick so i need to drain some out but could that have anything to do with it? Please help and thanks
it jumps mostly while accelerating probley in about 2nd or 3rd but also while at a steady speed in od. and like i said its random so usually after a couple miles or so.Im also starting to think (but hopefully it isnt) that my torque converter could be goin bad? Only reason i think its tranny or tc related is when it jumps you dont feel it in the truck as if the speeds changeing you just see it on the tach and hear it
it has about 105,000. Also i dont know if this is related or not but just read about it on a ford forum for failing tc symptoms. But when my truck has been sitting a while and i take off it will shudder a lil bit at low rpms while accelerating, usually goes away after about a block though. I always thought it was just from being cold but maybe not, its been sitting for 2 hours now so im gonna go run down the road and get back to ya on that.
well after driving just driving it i went around the block, didnt happen, so i jumped on the highway and it did it in 4th twice at 2300 and 2400 rpms then while turning around it did it at about 1500 rpms in 3rd never in first or second. And that was driving a total of about 10 miles and the 2 times in 4th were one after another
Trending Topics
