Suspension Lift question
Old May 23, 2011 | 02:19 PM
  #21
dkishton1486's Avatar
dkishton1486
Bump stop is on the frame
Old May 23, 2011 | 02:30 PM
  #22
only half the bumpstop is on the frame, the other part should be on the block, between the axle, and spring...... I can take a pic of my 96 if ya like. (provided my daughter hasn't ran off with it.......)
Old May 23, 2011 | 02:33 PM
  #23
97tn4x4's Avatar
97tn4x4
Just use grade 8 bolts for the center bolt. Those are probaly helper springs on top.
Old May 23, 2011 | 02:34 PM
  #24
dkishton1486
Can you please get me a pic?
Old May 23, 2011 | 02:42 PM
  #25
when the truck returns.... I will post a pic.
Old May 23, 2011 | 02:50 PM
  #26
97tn4x4's Avatar
97tn4x4
Ah the kids with your truck lol. Don't feel bad my 2 yr old tried
On another note You always need to replace your u bolts anyway and I've never seen an aal you reuse stock ubolts. Mine are like an inch tall.
Old May 23, 2011 | 03:00 PM
  #27
dkishton1486
so basically I should go and have sme new ones bent up that are like 1-2 inches longer then the stock ones?
Old May 23, 2011 | 03:18 PM
  #28
97tn4x4's Avatar
97tn4x4
Yep that's what you do. I don't think auto part stores sell 3" u bolts. You can go look cause they will certainly be cheaper. I think the ones I had bent were 60 and autozone had a set for 20.
Old May 23, 2011 | 03:19 PM
  #29
dkishton1486
The u bolts on my truck are about 17.5" long
Old May 23, 2011 | 03:24 PM
  #30
97tn4x4's Avatar
97tn4x4
I meant 3" wide. Go to a spring shop and have them bend you some 19" ubolts. It'll take like 2 minutes for them to do. It took me longer to pay than it did for the guy to bend them lol.
