tranny gurus help
Old 06-06-2011, 10:14 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Somebody looking for a transmission tech. I have always been here, all you need to do is write. First thing you need to do is find out why you have a code for the 3-4 shift no rpm drop. To check the torque converter for tcc, you need a scanner (DRB3) to do a torque converter stall test. If it stalls, then the torque converter is locking up. I do have the PDF files for all transmission codes. If you need some of them just, pm with your email address. Have you done any mods to the rear diff? Because that will throw the RPM off. In other words, If you are 4th gear and the speed is 60 mph and your tach reads 2500 rpm. You maybe running 3.92 or 4.10 gears. Just asking.
Old 06-06-2011, 10:21 PM
BackwoodsRam's Avatar
BackwoodsRam
BackwoodsRam is offline
my build sheet says 3.93 gears but no mods at all. And nothings changed since before it stoped working, it worked one day and not the next, how much do yall think a tranny shop would charge to do a stall check?
Old 06-06-2011, 10:26 PM
master tech
Like I posted, You need to find out why you have a 3/4 no rpm code. This could the reason why the tcc not lock up. I don't know if the shops around you have a DRB3 to perform a stall test. I a DRB3 all the time at the shop. I wouldn't know the labor rate the shops around would charge.
Old 06-06-2011, 10:43 PM
BackwoodsRam
Is the 3-4 shift soleniod part of the. Tcc lockup solenoid set and if so wheres a good place to get it from?
Old 06-06-2011, 11:13 PM
master tech
It could be the solenoid or no power for the relay. Yes it will cause a lock up problem.
Old 08-01-2011, 09:20 PM
BackwoodsRam
well it was an eterinity till i had the time to replace the soleniod set (and no money to take it to a shop) but i finnaly swaped in a new one. the job only took about an hour and a half, but now the old girl shift into overdrive just like she should. thanks for all the help guys
Old 08-01-2011, 09:32 PM
MonteC's Avatar
MonteC
MonteC is offline
tada! Feels good dont it?
Old 08-01-2011, 09:36 PM
BackwoodsRam
lol little bit, i was pretty nervous about pullin the vb out, but it wasnt that bad at all. especially with a grease pen to make what bolts went where lmao(or is that considered cheating?)
Old 08-01-2011, 09:38 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,274 Likes on 3,021 Posts
Yes, it is. So, next time you drop the valve body, you will have to wear a blindfold, to make up for your evil ways.
Old 08-02-2011, 02:12 PM
13binfantillery's Avatar
13binfantillery
13binfantillery is offline
Default curious
did you ever swap out those solenoids? i was wondering if changing those worked out in any way because my truck does the same thing...
Quick Reply: tranny gurus help
