Pulling my tranny this evening....
Old Aug 19, 2011 | 11:08 PM
  #101
MonteC's Avatar
MonteC
Can you take some pictures for me? Maybe I can spot something.
Old Aug 19, 2011 | 11:10 PM
  #102
rocky_mtn_ram's Avatar
rocky_mtn_ram
Got it. I just really didn't wanna lose any frictions outta the deal. That seems counterproductive. But whatever solves the issue I suppose. Another tidbit, I did buy a new O/D hub from with because the splines in mine had a few small chips on the teeth. I'm starting to wonder if the top surface on my old hib was worn just right, and now this newer one is just somehow thicker on top...my old one does look a tiny bit worn.
Old Aug 19, 2011 | 11:11 PM
  #103
rocky_mtn_ram
Its all apart at the moment, tell me what you want to see...reassemble it and snap a couple?
Old Aug 19, 2011 | 11:21 PM
  #104
rocky_mtn_ram
The freakin O/D roller clutch cage was upside down....DOH!!!!!!!!!!!
Thanks guys...reassembling, hopefully crisis averted.
Old Aug 19, 2011 | 11:22 PM
  #105
OOOooops?
At least you figgered it out NOW......
Old Aug 20, 2011 | 12:32 AM
  #106
J415's Avatar
J415
I KNEW it was something over looked!!! Been there, done that!!! I'm glad to here i was an easy fix. I'm curious to know what your measurement is know that you fixed it.
Old Aug 20, 2011 | 12:33 AM
  #107
rocky_mtn_ram
1.73...thoroughly bummed....
Old Aug 20, 2011 | 12:38 AM
  #108
rocky_mtn_ram
Tomorrow I'll try with the old hub installed...worth a shot at this point. I wonder if removing the upper of the two snap rings (the wavy straight one) under the O/D clutch pack would give me the clearance needed...I just don't wanna remove any frictions.
Old Aug 20, 2011 | 12:40 AM
  #109
J415's Avatar
J415
Why do you say that?
Old Aug 20, 2011 | 12:43 AM
  #110
rocky_mtn_ram
Because it still falls below the specs on the chart in the manual which says 1.75 is as low as it measures for shim thickness. Which means not even the smallest shim offered will work. The .108-.110 shim. And the tranny guy told me today that 99% of his rebuilds take the .183 shim. Technically, I'm getting measurements that would reflect 6 shim sizes smaller than that.
