Pulling my tranny this evening....
Old Aug 20, 2011 | 12:52 AM
  #111
J415's Avatar
J415
Did you get the same thickness OD clutchs/clutch pack that you had before? There are at least 2 different sizes as I recall.
Old Aug 20, 2011 | 01:11 AM
  #112
rocky_mtn_ram's Avatar
rocky_mtn_ram
I got the fricion pack that WIT recommended over the phone, guess I'll have to research that. I just see it being almost out of the question to have to remove a friction. Especially because I'm only .02" from the smallest shim. I'm at a loss, any my ol' lady's gettin grumpy, guess it's time to turn in for the evening. Back at it tomorrow. Thanks again gents.
Old Aug 20, 2011 | 02:16 AM
  #113
Slomojo's Avatar
Slomojo
HeyYou, seems to have all the answers... I love it!
Pipe Wrench for the O2 sensor. Just get a new one.
Probably late, but it actually is possible to remove the tranny without touching the exhaust.
What is needed is to put a jack under the tranny, remove all fluid lines, wires, and bolts holding the tranny in the truck, and then just roll the tranny back about 5-6 inches until you clear the exhaust pipe that crosses over from driver to passenger side under the tranny. At that point, drop the thing straight down and out and your golden.
4x4 and 35in. tires, you can practically sit in a lawnchair under your truck while you work on it there is so much space. Must be nice...
Old Aug 20, 2011 | 07:36 AM
  #114
MonteC's Avatar
MonteC
Something is def. wrong. If you could take pictures of each step you took so I can look at each part and see if there is anything I can pinpoint.
Old Aug 20, 2011 | 01:44 PM
  #115
rocky_mtn_ram
Ok here we go. I chronicled the teardown and will post quite a few pictures. We'll start with the face of the extension housing face up with the machined bars I was using for my measurements.
  #116
rocky_mtn_ram
Removing the round retaining snap ring.
Old Aug 20, 2011 | 01:46 PM
  #117
rocky_mtn_ram
Removing pressure plate from O/D clutch.
  #118
rocky_mtn_ram
Now onto the frictions and steels...
Old Aug 20, 2011 | 01:47 PM
  #119
rocky_mtn_ram
O/D clutch removed.
Old Aug 20, 2011 | 01:48 PM
  #120
rocky_mtn_ram
Removing access cover.
Removed.
