pre plenum checklist
Old Jul 26, 2011 | 03:40 PM
blackbeasst's Avatar
blackbeasst
Originally Posted by VWandDodge
Oh, you sad, sorry bastard.
i could just never get over the smell of it. HA!
Originally Posted by redheadhunter21
bypass hose goes between the water pump and intake manifold, its a pain an the *** to get to and cracks over time, its cheap and one of those things to change while it easy instead of going back in a week later to tear everything back down.
gotcha.
Old Jul 26, 2011 | 03:51 PM
Go for a new pump. If they have one with a lifetime warranty, get it.
They don't call beer "yeast ****" for nothin'. Although, I will grant that on the occasional really hot day, a nice, ice cold beer, DOES taste REALLY good.
Old Jul 26, 2011 | 03:57 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Beer is proof God wants us to be happy.
- Benjamin Franklin
Old Jul 28, 2011 | 10:45 AM
blackbeasst
heyyou, on the TC gasket set is says "must be used with OS 34409R" which is the oil pan gasket. why must i change my oil pan gasket to use the other gaskets?
Old Jul 28, 2011 | 11:25 AM
TheycallmeLaramie's Avatar
TheycallmeLaramie
doesn't hurt to change radiator hoses and add a flush kit adapter while stuff is drained too. I also put a new thermostat housing on it (10$). Make sure you rent a harmonic balancer puller, and since the two bottom timing chain bolts go through oil pan it doesnt hurt to have that gasket on hand just incase you F it up. I just returned it after i was done, but hate extra trips to the store. Anti-seize for your spark plugs, Di-electric grease if your nuts like me.
In my thread I did all of what your about to tackle with tons of pics if your interested:
https://dodgeforum.com/forum/2nd-gen...500-sport.html
Old Jul 28, 2011 | 11:40 AM
blackbeasst
yeah i already had to replace the lower radiator hose but i'll check on the others.
thanks for the tip on harmonic puller. yeah i got all the small greases and lubes on hand already!
thanks for the link. i know there are tons on the forum but it looks like all are different !
Old Jul 28, 2011 | 11:45 AM
You don't have to. I didn't. (although, I ended up doing the oil pump later...... so, it got a new gasket anyway......)
Old Jul 28, 2011 | 11:47 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Last time I had the thermostat housing out I took it and a few of the band clamps in to get powder coated. I primarily wanted the housing coated so it wouldn't have issues with corrosion getting worse (pitting already present) and possibly crumbling or blowing apart one day.
Old Jul 28, 2011 | 11:50 AM
blackbeasst
ok good. that part might come at a later date LOL!
Old Jul 29, 2011 | 07:47 AM
Novarider's Avatar
Novarider
If your plenum is blown then your cat is most likely clogged so you should either replace it or gut it. Also the pre cat 02 sensor
