I do not remember The Psi rating I used my buddy's gauge to check it a little while ago I just rembember it came out to a ratio just shy of 11:1 like 10.8, 10.9
Numbers are important here. They should have all been north of 150 PSI. If they were less than that, something is awry. If you have a valve that isn't fully closing, or opening all the way for that matter, would definitely give you some interesting running problems...
Give me a minuets and I call him and ask the gauge we used read in psi and under that it gave a comp rati reading I'll have him check what psi rating matches up with the 11:1 ratio
Mainly because of the price tag..... Not a cheap piece. Lot more accurate than the pedestal/stud mount guys though. Probably worth 10 to 15 horsepower just by virtue of the shaft.....
Yea they aren't cheap but I thought it might be nice to show everyone what they're like. And they are much stronger then the pedestal mount I always loved the shaft mount rockers of the LA engines
