mechanical fan removed power increase
Old Aug 21, 2011 | 02:47 PM
  #31
Hans_GZP's Avatar
Hans_GZP
The only problem with a percentage is that it's only good for stock vehicles. Once you modify, that percentage goes out the window.
I specialize in Mitsubishi 3000GT's and Dodge Stealth's. The turbo models make about 250-260 awhp stock (rated at 300-320 depending on year). Once you start modding them, that drivetrain loss isn't going to stay at 20ish %. You make 1000 awhp, you aren't losing 200 hp through the drivetrain. The heat produced from losing that much power would be insane!!!
Old Aug 21, 2011 | 03:11 PM
  #32
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by 93grandzj
So you doubting thomas's out there. Hot rod mag did a dyno tester with a S/C mustang if i remember correctly. in which the went around cali and hit up 5 different dyno in several hours. There numbers were like 30-60 different in Horse power and 25-60 diffenence in torque. At different sites elevation and make and models of the dyno. All three of my runs were with in 3hp and 3 lbs/ft of torque.
not stock if you can read!!!
spectre CAI and flowmaster exhaust muffler delete....
That may be true, but, I don't think people started off arguing that point. The above quote is what started it all. And that by far is no modified vehicle.
Old Aug 21, 2011 | 03:13 PM
  #33
aim4squirrels's Avatar
aim4squirrels
Boost changes everything. Not apples to apples.
Old Aug 21, 2011 | 03:30 PM
  #34
In all reality, drivetrain loss is going to be a product of friction, and the mass being moved, so, regardless of input power, the amount of power lost due to the drivetrain, should be a fixed number. (or, a fixed curve)
Old Aug 21, 2011 | 08:17 PM
  #35
BackwoodsRam's Avatar
BackwoodsRam
i hate math class
Old Aug 22, 2011 | 02:55 AM
  #36
93grandzj's Avatar
93grandzj
Yes, but stop calling it stock. When it has been modified. Ever so littlle as it is, is modified still. I am going to find another dyno place closer to home and with a little better rep. I will post pics once i get the scanned. I own more vehicles then technological advanced pieces that are computer accessories. It says dynojet atop my dyno sheet. It was mounted in floor with two separate drum pieces.
Old Aug 22, 2011 | 10:07 AM
  #37
Ugly1's Avatar
Ugly1
Old Aug 22, 2011 | 12:05 PM
  #38
BackwoodsRam
what ugly said
Old Aug 22, 2011 | 08:16 PM
  #39
lazyboy's Avatar
lazyboy
anyone want to share info on a good e-fan setup for these trucks? looking for good value, great reliability and good fit.
whats your advice?
thanks in advance
doug
Old Aug 22, 2011 | 08:31 PM
  #40
zman17's Avatar
zman17
Have you tried doing a search? There are lots of good threads on the topic.
