Transmission oil pan leaking
Old Sep 5, 2011 | 10:16 AM
Stoft's Avatar
Stoft
I ordered a new oil pan, gasket and filter now. Can someone of you do a superawesomhighskilled paint picture of where i should drill and weld the oilplug?
Thanks
Old Sep 5, 2011 | 10:22 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Do a search in 2nd gen ram section, I know a couple members had pics in a couple threads.
Here...... https://dodgeforum.com/forum/2nd-gen...in-plug-2.html
Old Sep 5, 2011 | 10:42 AM
aim4squirrels's Avatar
aim4squirrels
That pan is pretty thin, welding might not be your best bet.
Old Sep 5, 2011 | 10:47 AM
zman17's Avatar
zman17
I didn't notice he said that. Get one of these, no welding required.
Old Sep 5, 2011 | 10:55 AM
aim4squirrels
Looks like somebody already got that one.lol
Old Sep 5, 2011 | 10:59 AM
zman17's Avatar
zman17
Old Sep 5, 2011 | 11:15 AM
Stoft's Avatar
Stoft
Thanks!
No welding, i´m happy
Old Sep 5, 2011 | 12:14 PM
dhvaughan's Avatar
dhvaughan
here's your drain plug part numbers. price is anywhere from $3 to $20 for pretty much the same thing.
https://dodgeforum.com/forum/2nd-gen...drainplug.html
some location options (mostly on the bottom). unless you cut/grind off all excess height of the drain plug tube above the locknut, avoid the area under the solenoids.
i put one in a jeep awhile back and put the plug on the side to avoid it dragging. you don't have to drain all the fluid, just most of it to eliminate the mess when dropping the pan.
https://dodgeforum.com/forum/2nd-gen...rain-plug.html
Old Sep 5, 2011 | 03:14 PM
Stoft's Avatar
Stoft
My dealer hade this at home, http://www.summitracing.com/parts/MRG-4470/?rtype=10
So tomorrow I will go and pick that one up and 8 litres of Mopar ATF+4 Oil
Old Sep 5, 2011 | 03:20 PM
zman17's Avatar
zman17
Nothing wrong with that one either. I just don't like the Dorman ones because the center plug is regular thread and uses a gasket. But that one and the B&M, the center plug is pipe thread.
