Why??
Although I too have provided a few people with the link for replacing the HC without touching the AC. There is NO way I would do that myself. The Evap core is almost just as common a problem as the HC is. You can't clean the box out properly(all the crap in there is the problem), and the evap core should be replaced at the same time. Unless of course you want to tear the whole thing apart again.
The right way can be found in the FAQ/DIY section. As in the original link posted here by someone.
You don't have to remove the vents, it's the only good part about the job.
