trans problem
Old 10-06-2011, 03:44 PM
Shaun Hamilton's Avatar
Shaun Hamilton
Shaun Hamilton is offline
Default trans problem
Hello everyone,
I'm having problems with my trans. I have a 97 dodge 2500 5.9 with 96,000 miles and with either a 47re or 48re trans. ( i forget what dealer said) It started when i hooked up my trailer 3,000lbs and noticed it was slipping. I did a service filter and fluid and added lucus. No more slipping shifts good. Now it seeps to be shifting hard so i took it to 2 trans shops to have it looked at. He said had no codes and smelled good and nothing in the pan. They test drove it and could not duplicate my problem. No when i pull in my driveway it will shift from 1st to 2nd fine but no power at all in 2nd i have to manually put it back into 1st. only under a load and with trailer. I had a few people talk about adjusting a band? Just wanted to get everyone's opinion.
Also me speedometer is 8mph faster then the truck. Has stock rims and tires. No mods. I was told try speed sensor first that could cause shirting problems. Again no pending or current codes. Thanks a lot
Old 10-06-2011, 04:18 PM
8uzzsaw's Avatar
8uzzsaw
8uzzsaw is offline
Isn't there a Vehicle Speed Sensor on the back of the transmission that would give you those symptoms? Might want to check that too.
https://dodgeforum.com/forum/newrepl...te=1&p=2613984
Might try looking in that link to get more info.
Good luck!
Old 10-06-2011, 04:38 PM
Shaun Hamilton
Ok thanks. Any ideas where i should start first?
Old 10-06-2011, 04:52 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,390 Likes on 3,130 Posts
97 should have a gear driven VSS in the back of the trans, or, output housing on the t-case. Might be as simple as a gear change there.
Would that be the 5.9 diesel?
Old 10-06-2011, 05:04 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
That would be nice to know, because if it 's a gasser, I know at least where I'm going with this.
Old 10-06-2011, 07:22 PM
Shaun Hamilton
Sorry guys. Its gas
Old 10-06-2011, 07:24 PM
zman17's Avatar
zman17
zman17 is offline
In that case, you have a 46RE tranny. And as far as power loss goes, I suggest you read the plenum sticky on top of the page(and address that issue), before trying to diagnose a tranny problem you may not have.
Old 10-06-2011, 07:28 PM
Shaun Hamilton
Ok great thanks. Would this help with it shifting hard. One thing the trans guy did say it shifts to soon out of 1st so when it hits 2nd not enough rpm's. Sorry guys i dont know **** about this stuff
Old 10-06-2011, 08:01 PM
zman17's Avatar
zman17
zman17 is offline
You might have a Governor Solenoid problem too. But, I think you should check the plenum and cat first.
Old 10-06-2011, 10:00 PM
Shaun Hamilton
I looked in the intake and there is no oil. It is a little dirty so i just did the seafoam treatment through the brake booster hose. Any other signs of that gasket needing replaced? Runs really good with no trailer. Maybe just a good tune up? back on the trans the first shop road around with a computer and said its about 10psi lower then should be but he wasn't worried about it. Any thought on that? Thanks a lot
Quick Reply: trans problem
