trans problem
Old 10-07-2011, 07:43 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Originally Posted by Shaun Hamilton
I looked in the intake and there is no oil. It is a little dirty so i just did the seafoam treatment through the brake booster hose. Any other signs of that gasket needing replaced? Runs really good with no trailer. Maybe just a good tune up? back on the trans the first shop road around with a computer and said its about 10psi lower then should be but he wasn't worried about it. Any thought on that? Thanks a lot
I'd replace the Gov pressure switch and solenoid.
Old 10-07-2011, 08:40 AM
Shaun Hamilton's Avatar
Shaun Hamilton
Shaun Hamilton is offline
Thanks a lot. I just made an appointment at trans shop. He said just under $400 to service it, adjust the bands if needed, replace both solenoids, take out some plate and clean it. Does that sound like a ok price?
Old 10-07-2011, 09:00 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,275 Likes on 3,022 Posts
Only if it includes parts, and a Kiss first........
Old 10-07-2011, 09:46 AM
Shaun Hamilton
LOL it includes the parts.
Old 10-07-2011, 05:30 PM
zman17's Avatar
zman17
zman17 is offline
I guess that sounds like a fair price. The plate he is talking about , is probably the Governor body. I forget which years at the moment, but the pressure switches are mounted differently and some require the removal of the Gov body the replace the pressure switch.
Old 10-07-2011, 09:52 PM
Shaun Hamilton
I might need that gasket you were talking about. I looked in the intake and i see wet spots. also when i gas on it, it sounds like a sucking noise. Sounds like it might be coming from near the air filter housing tho. Doesnt use any oil. o well guess another project on a rainy day. Thanks a lot for you input
Old 10-07-2011, 10:32 PM
gdstock's Avatar
gdstock
gdstock is offline
I would say that "might" may be an understatement. Sounds like plenum repair needed. Changing the plate is highly recommended - to keep from having to make this repair on a routine basis. Plate can be bought on e-bay for $50, including bolts.
Old 10-08-2011, 07:48 AM
Shaun Hamilton
ok great i will check that out. Also 1 last question. my speedometer is about 8mph faster then the truck is going and i noticed last night i have 2 different size tires 245/75/16 on the front and 245/70/16 on rear. could this make speed o be off or have anything to do with trans acting up. I will not run 4x4 until i get all same size. the truck calls for 245/75/16.
Old 10-08-2011, 07:51 AM
zman17's Avatar
zman17
zman17 is offline
Put the front ones on the rear and see if it fixes the speedo.
Old 10-08-2011, 08:09 AM
zman17's Avatar
zman17
zman17 is offline
No prob. Just curious, how do you know it's 8mph off?
Quick Reply: trans problem
